new to hondas, need help with door panel
i need to get my door panel off, but i don't know where all of the screws are. is there a combination of screws and clips? if someone could help me that would be great. thanx
there should be 3 or 4 screws. then a ton of clips...after you get all the obviouse screws off, just pull and u'll hear the clips poping...wala door pannel is off.
Its pretty straight forward. There are 6 screws that hold the door panel on. @ should be behind the speaker grill, one on the back of the door, one on the grip part of the panel(where you reach for to close the door) and another one near the outside mirror. After you have unscrewed those use a panel popper to pop the clips out. hth
the window roller is the trickiest. it's a pain in the *** sometimes, just make sure you have light to take the pin out and put it in.
I just put a towel around the closed side of the pin, so that when I push the open end through the rod and it pops off, it's in the towel. Kind of like a condom for my door window crank.
casper.hughes
Oct 12, 2008 06:33 PM
integracura
Dec 17, 2007 02:06 PM
