question about wastegate spring and boost
I have a HKS wastegate with the smallest spring (5lbs or so). I also have a Greddy profec B. I run normally 8-9lbs, never higher than that and usually not lower than that. My question is; would the boost come on faster if you have a wastegate spring that is closer to the boost you are running? Such as if I bought a 7lb spring.
scott
98 ITR turbo
scott
98 ITR turbo
95srv
May 12, 2006 07:09 AM
Cyber ITR
Jan 19, 2004 03:38 AM
