Oil relocation kits
Old Jan 9, 2003 | 06:36 PM
vtec.dc2's Avatar
Default Oil Filter relocation kits
Oil Filter Relocation Kit
Anyone used greddy kit or has advice on which one to use?
here a link for greddy http://greddy.com/products/OilCoolerKit.htm
[Modified by vtec.dc2, 10:38 PM 1/9/2003]
Old Jan 9, 2003 | 10:08 PM
sgT's Avatar
sgT
Default Re: Oil Filter relocation kits (vtec.dc2)
first of all, why do you want to relocate?
Old Jan 9, 2003 | 11:40 PM
B2FiNiTY's Avatar
Default Re: Oil Filter relocation kits (sgT)
"This kit allows you to relocate the factory oil filter for easy maintenance with a trick look. "
I'm guessing he wants the trick look
Old Jan 10, 2003 | 04:15 AM
Dirt's Avatar
Assuming you can find a spot in the engine bay, oil changes will be much quicker (no need for ramps or jackstannds). You do not need to raise the car to get at the drain plug. Good idea if you want to use a larger filter also, but this looks like it uses the stock filter size.
Old Jan 10, 2003 | 04:22 AM
ITR764's Avatar
Default Re: Oil Filter relocation kits (BrewCityR)
are you in some kind of race to see who can do a faster oil change??
Old Jan 10, 2003 | 05:09 AM
00 FBP ItR's Avatar
Default Re: Oil Filter relocation kits (ITR764)
or maybe he wants to run an external oil cooler.. so he relocates as well.
Old Jan 10, 2003 | 05:22 AM
Dirt's Avatar
Ha, no, but I'm just remembering when I changed my oil in my beater about 3 weeks ago in 25 degree weather. Cold sucks.
Old Jan 10, 2003 | 05:53 AM
Mugen Mike's Avatar
huh? No way in hell I can get to my drain plug w/o jacking it up.
Old Jan 10, 2003 | 07:40 AM
vtec.dc2's Avatar
pretty much for the reasons stated above, but i think i'll leave it as it is..
Old Jan 10, 2003 | 07:57 AM
io_burn's Avatar
New User
I don't know why the **** cars don't come from the factory with the oil filter and drain plugs in easy to get to locations. I mean ****, I change my oil more than I fill my washer fluid. My Jeep is just god damn ridiculous to change the oil, I cut the **** out of my hand every time I do it because of the completely assinine place the oil filter is at.
Old Jan 10, 2003 | 08:03 AM
Chris N's Avatar
Default Re: Oil Filter relocation kits (io_burn)
The drail plug has to be on the bottom of the pan. It IS in the best place it can be.
As for the filter, well, it could be in a better spot but it isn't that bad.
Old Jan 10, 2003 | 08:34 AM
Mugen Mike's Avatar
Default Re: Oil Filter relocation kits (Chris N)
No way, Chris.It would be sooo much easier to get at if it were on top of the valve cover
Old Jan 10, 2003 | 01:24 PM
PupaScoopa's Avatar
Default Re: Oil Filter relocation kits (MugenMike)
Wait a sec... the filter relocation kit does nothing for draining the oil: you still have to drain under the oil pan. It DOES make changing the filter easier AND allows the use of a bigger filter (or even two filters) for the ultimate in filtering.
Amsoil makes an awesome looking set too, single and dual filters up to 15" long
Old Jan 10, 2003 | 01:26 PM
io_burn's Avatar
New User
Default Re: Oil Filter relocation kits (PupaScoopa)
You could get one of those cool oil drain plugs though that are like the nipple valve or whatever... you wouldn't even have to jack up the car then
sgT's Avatar
sgT
The drail plug has to be on the bottom of the pan. It IS in the best place it can be.No way, Chris.It would be sooo much easier to get at if it were on top of the valve cover
what you mean the plug on the valvecover isnt the drain?
Old Jan 10, 2003 | 01:28 PM
vtecvoodoo's Avatar
Future Texas Boy
Community Builder
I have the b&m oil cooler, which relocates the filter. Not too shabby for $100.
Old Jan 10, 2003 | 01:32 PM
sgT's Avatar
sgT
Default Re: Oil Filter relocation kits (vtecvoodoo)
mine doesnt relocate the filter.
unless you mean relocates it 1" farther out
Old Jan 10, 2003 | 01:33 PM
Chris N's Avatar
He means he wants his oil to come out the top the valve cover with some neat hose, instead of out the bottom.
They are bitching because they have to jack up their car to change their oil.
Old Jan 10, 2003 | 01:34 PM
vtecvoodoo's Avatar
Future Texas Boy
Community Builder
Really? That`s weird.
Old Jan 10, 2003 | 01:36 PM
sgT's Avatar
sgT
maybe the place you got yours from did that for you.
none of the ones i have seen do that.
Old Jan 10, 2003 | 01:41 PM
vtecvoodoo's Avatar
Future Texas Boy
Community Builder
Nah, it`s just standard off the shelf from pro-motion. Maybe it`s a pushrod unit
Old Jan 10, 2003 | 01:43 PM
TypeR76's Avatar
I had one on my car for a month. It's POS. Period.
Old Jan 10, 2003 | 02:06 PM
Misfit's Avatar
Default Re: Oil Filter relocation kits (TypeR76)
just relocate it to the trunk...while your at it put your battery back there.
Old Jan 10, 2003 | 02:22 PM
Austin's Avatar
The one I have sitting at home in a box relocated the filter too...I've just been too damn lazy to install it, especially considering I want all SS lines.
Old Jan 10, 2003 | 04:05 PM
Tweakmeister's Avatar
Default Re: Oil Filter relocation kits (Austin)
Jackson Racing sells an all in one cooler/relocation kit....it's the cheapest combo setup I've found.
kegler4ever
Honda Civic (2006 - 2015)
13
Dec 1, 2006 11:18 AM
TurboEM1
May 5, 2006 07:15 AM
FLATL1N3R
Sep 6, 2005 08:18 AM
SuicideSlide
23
Jun 12, 2005 12:11 PM
travis
Nov 9, 2001 11:11 AM
