type r lsd ?... desperately need help
Old Jan 9, 2003 | 04:48 PM
93b18civic's Avatar
Default type r lsd ?... desperately need help...tonite
found a swap that allegedly has a type r lsd and gears in a gsr housing. how can i tell??? i have a pic from each side of the x-fer case. let me know if you can tell me for sure if it has it or not. i dont have it yet because i want to know if it is for sure lsd. let me know. thank you for your help.
[Modified by 93b18civic, 3:09 AM 1/10/2003]
Old Jan 9, 2003 | 05:14 PM
93b18civic's Avatar
Default Re: type r lsd ?... desperately need help (93b18civic)
come on now please help me. i need to know tonite. thanks
Old Jan 9, 2003 | 05:18 PM
b18c1_powered_si's Avatar
there is no way u could see thru a trannie if u have the intermediate shaft in the way. unless u have to have even more detail pics on the axle seal hole.
[Modified by b18c1_powered_si, 6:19 PM 1/9/2003]
Old Jan 9, 2003 | 05:20 PM
markpaco's Avatar
The intermediate shaft side doesn't tell you anything. But the other side does. It looks like it has LSD. As for the gears, you will either have split the case and count the teeth or use a speed calculator to find out the speed in each gear.
edit: I guess you didn't understand what I basically said: IT HAS AN LSD
[Modified by markpaco, 2:43 AM 1/10/2003]
Old Jan 9, 2003 | 05:35 PM
93b18civic's Avatar
Default Re: type r lsd ?... desperately need help (b18c1_powered_si)
this is pics from both sides. intermediate shaft tells nothing. i got that. but what about the other pic? its of the diff. let me know. thanks
[Modified by 93b18civic, 2:37 AM 1/10/2003]
Old Jan 9, 2003 | 06:51 PM
93b18civic's Avatar
found out its a ys1 tranny...... does this help????
Old Jan 9, 2003 | 07:43 PM
ys1 i believe is cable trannie. it might be a y21 is u look closely. that's a b16a trannie
Old Jan 9, 2003 | 07:58 PM
93b18civic's Avatar
heres the tranny
Old Jan 9, 2003 | 08:03 PM
93b18civic's Avatar
cable? its hard for me to see
Old Jan 9, 2003 | 08:04 PM
maybe the original casing was damaged so they swap over another casing. i'm pretty sure tha'ts a cable trannie casing. unless i'm wrong of course.
Old Jan 9, 2003 | 08:20 PM
Big Teggie's Avatar
Default Re: type r lsd ?... desperately need help...tonite (93b18civic)
Take out the intermediate shaft. Then take some pics. If you can see thru the diff it is an ITR LSD.
Old Jan 9, 2003 | 09:40 PM
Nameless RB26's Avatar
Default Re: type r lsd ?... desperately need help...tonite (Big Teggie)
From what I can see, it looks like it has an LSD. Although to be 100% sure, you should take out that midshaft.
As for it having Type R gears... that's too hard to tell unless you split the case and compare gears etc. to the GSR internals..
Old Jan 10, 2003 | 06:33 PM
93b18civic's Avatar
Default Re: type r lsd ?... desperately need help...tonite (Nameless)
found out its not gunna work for me but thanks for all the help.
mitcho168
Acura TL, RL & ZDX
Jan 30, 2009 03:27 PM
r1ch1e
Apr 7, 2007 08:49 AM
1fastcivicsi
Sep 4, 2004 11:32 PM
93b18civic
May 5, 2002 03:19 PM
RPM_CRAZY
Mar 5, 2002 11:35 AM
