Is a Benen cross member bar the same as a lower tie bar?
Old Jan 9, 2003 | 03:21 PM
Raocorp's Avatar
Default Is a Benen cross member bar the same as a lower tie bar?
First off I know what a cross member is but does Benen sell a cross member brace or an upgraded cross member? Or is it the same as a lower tie bar?
the pic from Benen:
Old Jan 9, 2003 | 04:25 PM
maxim's Avatar
Default Re: Is a Benen cross member bar the same as a lower tie bar? (Raocorp)
no, it is not the same. It is an "upgraded cross member."
Old Jan 9, 2003 | 05:34 PM
euclid's Avatar
Default Re: Is a Benen cross member bar the same as a lower tie bar? (maxim)
it mounts in you engine bay, directly in front of the steering column... get that bar and a front lower tie bar, and afront strut bar... your steering response will be 100%better
Old Jan 9, 2003 | 05:40 PM
redman223's Avatar
Default Re: Is a Benen cross member bar the same as a lower tie bar? (euclid)
Are there any pics of it installed? Are there any fitment issues with it whatsoever?
Old Jan 9, 2003 | 05:46 PM
euclid's Avatar
Default Re: Is a Benen cross member bar the same as a lower tie bar? (redman223)
Are there any fitment issues with it whatsoever?[/QUOTE]
i have a power steering rack and it was a really close fit, like 1mm... and i had to disconnect the mounting bracket for a p.s. hardline that uses the same hole in the chasis that the crossmember bar does. but im not having any problems w/ it after it was installed. its a pain in the *** to manuever the bar into where it is susposed to be mounted but i had the cusco front lower bar on already so that made it alittle tougher. just give yourself an hour, it'll definately fit, it just takes some patience b/c theres alot of **** in that area of the car.
Old Jan 9, 2003 | 06:43 PM
Raocorp's Avatar
cool thanks.
so then the original bar is removed and replace with the benen bar.....correct?
Old Jan 9, 2003 | 07:14 PM
kommon_sense's Avatar
anyone happen to have a pic of this thing installed?
Old Jan 9, 2003 | 07:21 PM
eg6sir-s's Avatar
this bar is serves the same purpose as the bar that comes on the 94-01 integra. save some cash and be practical and buy one off an integra and save some cash...and for those that dont mind spending a little more than others, go for it.
[Modified by eg6si, 8:22 PM 1/9/2003]
Old Jan 9, 2003 | 07:39 PM
ATS*Mark's Avatar
OG triple OG
Default Re: Is a Benen cross member bar the same as a lower tie bar? (eg6si)
hmmm , are u tellin me i just found another bar i can stick somewhere????? tight tight!!! consider it ordered
Old Jan 9, 2003 | 08:13 PM
JSJ EG6's Avatar
Default Re: Is a Benen cross member bar the same as a lower tie bar? (TeamUntouchableRacing)
can the stock 94-01 integra cross member fit 92-95 hatch with a b series motor and stock motor?cuz it looks like the bar will hit the shift link age.
Old Jan 9, 2003 | 09:19 PM
JDMb18civic's Avatar
Default Re: Is a Benen cross member bar the same as a lower tie bar? (TEAM JSJ)
i think you guys got it all mixed up...
that pic is the one that goes to the back
its the bottom one
Old Jan 9, 2003 | 10:24 PM
JSJ EG6's Avatar
Default Re: Is a Benen cross member bar the same as a lower tie bar? (JDMb18civic)
i thought that bar is called a strong bar?and the cross member go by the shift like age???
Old Jan 9, 2003 | 11:29 PM
eg6sir-s's Avatar
cars that i put the stock gsr chassis bar on:
1993 lx civic sedan automatic
1993 si del sol
1993 civic si hatchback
Old Jan 9, 2003 | 11:34 PM
eg6sir-s's Avatar
its the bottom one
the strong bar is a replacement for the rear bumper support when drag racers take it off...
Old Jan 10, 2003 | 05:48 AM
Raocorp's Avatar
its the bottom one
No, that is not the cross member. That is the strong bar....the cross member goes underneath the car. I just wanted to know if the Si has one stock and if this is a replacement bar. Now I know that it can be used in conjuction with front lower tie bar. I think I may look into the integra bar though. May be difficult to get a hold of one in good shape though. The dealer would for sure charge a lot of money, and the scrap yards might not have anything in decent shape and I doubt anybody would be selling one off their car but anything is possible.
eg6si: Are the integra bars beefie bars? Is one from an ITR better/thicker/stronger than one from a gs or gsr? or are they all the same?
TeamUntouchableRacing: check this out....don't know if you have one of these already but you seem to be "bar" crazy like me. Its called a C-pillar bar from J's racing.
here is a pic of it installed on an integra:
They can be purchased from jdmspecperf.com. Here is the direct link to their
page
http://www.jdmspecperf.com/products/...ts.asp?type=js
chinkyx90
Suspension & Brakes
Mar 11, 2009 03:43 AM
Live*JDM
Suspension & Brakes
Dec 20, 2007 07:25 AM
LSVTECoupe
Jul 23, 2003 12:20 AM
