VTEC Engagement Question
I read somewhere that you can buy an aftermarket chip that lowers the VTEC engagement.
Just wondering if this does any damage to the engine, or is a disadvantage in any way?
you should get a V-AFC. You can lower and raise your redline as you see fit. you can also control the air to fuel ratio in your car and if you have other mods such as Intake, header, and exhaust you can see some nice gains on the dyno. I think the price is around 325. try http://www.nipponpower.com
keep in mind that when you lower the VTEC engagement you get a lot worse gas mileage since it burns more gas in vtec.
Is the VAFC difficlut to insall or do you guys reccomend that it be professionally done?
[Modified by LordVtec, 9:46 PM 1/9/2003]
dont you save gas when not in vtec because you lower your fuel clurve, i heard the ludes come rinning rich from factory
If you richen (add fuel) to your curve=worse gas mileage.
If you lean (remove fuel)=better gas mileage.
here comes the saying Tuning Is Everything..
Lord , is it still worth it to put in the VAFC even if it's gonna be a street car? I'm just looking for preformance out of the lude. Eventually maybe do some mods when I have the time and money, but you guys make it seem that its a good buy all around. Am I correct?
