Brake Pads uneven waer
Is it normal or is there something wrong with my car?
I had my brakes changed both front and rear, upon replacement of the fronts, the front passenger side pads were worn way more the the front drivers side pads.
[Modified by IntegraGSR23, 11:55 AM 1/9/2003]
maybe the caliper or pads are stuck and dragging... when you changed the brakes did you make sure the pin bolts and everything was lubed up w/ high temp brake grease and that the caliper slides freely? this happened on my friends car where the caliper was not able to slide freely so one side wore quicker than the other...
I had a similar situation. When I finally got to look at my car it turned out that both calipers had seized up; likewise, one side was only getting pad to disc contact on the outside and the other side was only getting pad contact on the inside. I did not experience brake fade whatsoever. You might want to check for rust on the caliper either on the inside or outside.
[Modified by Mikey, 2:17 PM 1/9/2003]
I only have 75k. I guess I will wait till next time around to see if it does it again, cause I put new rotors in too.
Would a worn rotor cause excessive wear on one side only? I know they were pretty worn
i have a similar problem, my right side inner pad was worn almost completely away whereas the outer right pad had about 60% meat left on it. the right outer pad looked like new and the inner one was fairly similar. I'm changing them again this weekend, and will make sure that the pins/bolts are cleaned and well greased up before putting the new ones in
