rear lower control arm ??
Old Jan 9, 2003 | 09:59 AM
honda25's Avatar
Default rear lower control arm ??
I have a 93 civic coupe
will the control arms from GSR fit ??
will the contro arms from type r fit ??
these are the ones i am looking to buy - SO WILL THEY FIT MY 93 civic coupe
Old Jan 9, 2003 | 10:16 AM
honda25's Avatar
Default Re: rear lower control arm ?? (muzikant25)
ttt
Old Jan 9, 2003 | 10:19 AM
BROOD's Avatar
Those will work...same lca's on GSRs and DelSol Vtec cars with rear sways. These will work fine for your 93 Civic coupe. Check out the bushing condition before bolting it up to your car. They are eisier to replace while off the car now...if needed. You will use the endlinks from a GSR, DelSol DOHC Vtec with the sway bar.
The ITR lca's look alot differently and require different rear struts.
**to add some installed photos**
https://honda-tech.com/zerothread?id=381752
[Modified by SLPR, 12:18 PM 1/10/2003]
Old Jan 9, 2003 | 11:00 AM
Tomek's Avatar
Default Re: rear lower control arm ?? (SLPR)
if you use the type-r lcas you will also need struts for a type-r
EDIT: I just realized the above post did mention that, my bad
[Modified by AztecEJ, 8:01 PM 1/9/2003]
Old Jan 9, 2003 | 11:51 AM
EK MONEY's Avatar
Default Re: rear lower control arm ?? (AztecEJ)
true and true
pablopab50
Suspension & Brakes
Aug 21, 2013 08:47 PM
boostjunkieee
Suspension & Brakes
10
Apr 15, 2011 05:07 PM
orlandoEM2
Honda Civic (2001 - 2005)
Dec 7, 2008 10:55 AM
Gonzo
Nov 6, 2002 06:24 AM
ThatDude
Feb 19, 2002 05:58 PM
