Rear Lip Mounting Question
Old Jan 9, 2003 | 09:40 AM
FrankandTim's Avatar
Default Rear Lip Mounting Question
OK, i was dumb and bought these oem rear lip pieces used and w/ no mounting hardware.
I just got the template, thanks to Aaron.
Now i have a question....
It looks like for these two, i can just use a normal honda 10 mm bolt....correct me if im wrong
now this is where i have no idea. what can i use for this mounting point???
TIA
Old Jan 9, 2003 | 09:48 AM
satintegra's Avatar
Default Re: Rear Lip Mounting Question (Stevo)
for the last one, there's a square headed bolt you have to drill onto the bumper.
Old Jan 9, 2003 | 10:04 AM
Default Re: Rear Lip Mounting Question (satintegra)
do you think i could go to a hardware store and find a square headed bolt to use?
Old Jan 9, 2003 | 10:22 AM
satintegra's Avatar
did you not get it when you purchased your oem pieces? it should have been included.
Old Jan 9, 2003 | 10:25 AM
nope, i bought them used
Old Jan 9, 2003 | 11:07 AM
Aaron M's Avatar
You need 2 of these. I'm trying to get 1 myself, and so far, honda, acura and home depot do not have them.
Old Jan 9, 2003 | 11:28 AM
Default Re: Rear Lip Mounting Question (SilverB18C1)
i thought about doing this:
and using this
what do you guys think?
[Modified by Stevo, 3:28 PM 1/9/2003]
Old Jan 9, 2003 | 11:36 AM
Chronicsinners's Avatar
that looks to be an acceptable substitute
Old Jan 9, 2003 | 11:47 AM
Aaron M's Avatar
Default Re: Rear Lip Mounting Question (Chronicsinners)
intresting, where did you get that clip from?
Old Jan 9, 2003 | 12:33 PM
junglistgsr's Avatar
its the same kind of clip that clips onto the stock bumper and OEM lip to hold it on...they have em at acura dealers for like $1.50 each
Old Jan 9, 2003 | 03:21 PM
Default Re: Rear Lip Mounting Question (junglistgsr)
i got it from a local parts store
Old Jan 9, 2003 | 05:42 PM
satintegra's Avatar
if you could thread on a nut on that screw, then it should work.
supracrx
Paint and Body
Jun 1, 2011 09:48 AM
baz_gti
Nov 22, 2007 05:35 AM
b0yg0tskills
Honda Civic (2001 - 2005)
May 3, 2007 07:51 PM
Lro255
Mar 4, 2007 10:34 PM
philibuster
Oct 4, 2005 12:20 PM
