injector cleaning
Old Jan 9, 2003 | 09:34 AM
NateTEG95's Avatar
Default injector cleaning
What kind of injection cleaner do you use?
Old Jan 9, 2003 | 10:19 AM
Eva01's Avatar
Default Re: injector cleaning (NateTEG92)
Gumout Regane
Old Jan 9, 2003 | 11:03 AM
GSRaCeRbOI's Avatar
I've used STP fuel system cleaner and Chevron w/ Techron
Old Jan 9, 2003 | 11:14 AM
NateTEG95's Avatar
Default Re: injector cleaning (GSRaCeRbOI)
Cool Thanks
Old Jan 9, 2003 | 12:38 PM
Aaron M's Avatar
do these fuel/injector cleaners actually do anything?
Old Jan 9, 2003 | 12:41 PM
emr88's Avatar
Default Re: injector cleaning (SilverB18C1)
I don't know if this means anything, but a Honda technician once told me that Cheveron w/Techron is all you need for injector cleaning.
If you have lots o' miles then the best thing would be to remove then and have RC Engineering clean them.
Old Jan 9, 2003 | 01:24 PM
The-LS's Avatar
Default Re: injector cleaning (emr88)
paid $90 to have the fuel rail tapped, cleaned the injectors and fuel rail. takes about 20-30 minutes.
Old Jan 9, 2003 | 02:00 PM
JeremyL's Avatar
Default Re: injector cleaning (RayRay000)
drive to almost empty, fill halfway up with 93 Octane pour in bottle of injector cleaner fill rest of tank with same 93 Octane and when you drive away peg the tach for about a mile or so and that should unclog just about anything clogging your injectors...its worked for me several times in the past with several different cars
Old Jan 9, 2003 | 04:55 PM
mugenracer's Avatar
Default Re: injector cleaning (JeremyL)
I've been using RedX injector cleaner for years, i dont know if it helps any but i suppose it does unclog some of the crap in them, I usually stick in half a bottle every 3/4 months or so
Old Jan 9, 2003 | 05:52 PM
10K2HVN's Avatar
VP injector cleaner...0WN3D the clogs in my injectors...!!
Old Jan 9, 2003 | 05:53 PM
JeremyL's Avatar
Default Re: injector cleaning (10K2HVN)
it could also be your o2 sensor if youre getting crappy mpg
movingIIshadow
30
Feb 29, 2020 07:36 AM
crj_lll
Mar 30, 2006 09:42 AM
payneth
Jan 7, 2004 01:00 PM
Platoon918
Apr 25, 2003 06:49 AM
