rear camber question
i know your supposed to shimm the rear with washers to get the camber to be right.
where do these washers go?
also how much do you have to shimm it i have newspeed race springs and agx struts. if i over adjust with too many washers can the alignment center adjust the toe to be right ??
thanks alot
-larry
thanks alot
-larry
Shim until you get the alignment you want..
some people want diffferent degrees of camber in the back...
As for the fronts.. SPC makes great quality stuff..
adjustable ball joints or the ingals sytle.. skunk2 makes an adjustable ball joint style too.....
The eibach kit is made by spc
all are about 150..
all are about 150..
You can get a cheap one from Napa for like 80-90 bucks... from what i hear it does the job, thats the one im planning to get unless i find a better one for about the same price...
SkyeC
Mar 10, 2003 05:11 PM
