tranny prob.?????
Old Jan 8, 2003 | 08:23 PM
stRtypR25's Avatar
Default tranny prob.?????
ok i am the one with the R that wont start after the tranny install,my buddy if typeRicer hater, just so there is no questions.
ok we tightned the starter and then we tried to turned the crankshaft pully but everytime we turned it, it went right back to it's orginal position. what do you guys think the prob is now?
[Modified by stRtypR25, 5:24 AM 1/9/2003]
Old Jan 8, 2003 | 08:26 PM
RagingAngel's Avatar
Default Re: tranny prob.????? (stRtypR25)
is it me or can anybody else figure out what this gentleman is trying to say?
Old Jan 8, 2003 | 08:29 PM
B2FiNiTY's Avatar
Default Re: tranny prob.????? (RagingAngel)
He is the guy that can't start his car. TypeRice Hater is his friend. Everytime he cranks it it goes back to the original place.
Old Jan 8, 2003 | 08:30 PM
stRtypR25's Avatar
what is there not to understand, look at the post created by typeRicer hater, if still confused
Old Jan 8, 2003 | 08:55 PM
stRtypR25's Avatar
still need help guys?????
Old Jan 9, 2003 | 05:19 PM
ultimatehonda's Avatar
If you want to rotate the crank to a certain point just pull the plugs and there will be no compression, so it wont go back.
[Modified by ultimatehonda, 9:29 PM 1/9/2003]
Old Jan 9, 2003 | 06:48 PM
JPP's Avatar
JPP
As mention above, you can remove the spark plugs to help you rotate the crank pulley. Then try the starter again to see if it will engagen the flywheel.
As a last resort, you could "compression start" the car (by pushing the car and droping the clucth in first gear with the ignition on) and see if at least the clutch is working properly (all gears engages smoothly). Then go back home and try the starter again.
Beats Bang
Honda Civic (2001 - 2005)
29
Mar 26, 2019 10:13 AM
varelaf
Jul 14, 2017 02:33 AM
maxcivic02
Mar 24, 2014 03:21 PM
Kusai.Nihonjin.Desu
Aug 28, 2003 12:49 PM
turbo_ef9
Mar 26, 2002 06:06 AM
