type r cluster in obd1 integra
the OBD 1 wont affect it. my friend has a 99 LS converted to obd1 and his Jdm R cluster works fine.
I think you might have a problem with differing years though. the guy i bought my JDM R cluster from had it in his 95 integra. to solve the problem, you should be able to just switch over the green "film" on the back of the cluster. i did that for my cluster and it works fine in my 98 GSR.
i am planning on doing this as well... i know the plugs will fit no problem but the wiring is going to be a little different.
i am trying to plug in a 00-01 usdm type r cluster does anyone know which wires on the 94 integra cluster plugs need to be switched or repinned inorder for all the corresponding gauges to function correctly?
i just had the same problem. my car is a 96 w/ reprogrammed p28 ecu. I had a 98 itr cluster and the fuel gauge didnt work. I just switched out the green film and it worked. just dont lose any bulbs and screws! good luck
talk about back from the DEAD!! 2 years OLD!!
any way, i just plugged a unknown year ls cluster (has same numbered green film as a obd1 gsr -so i guess it's 94-5) into a 01 ITR..the heat guage went fully hot...but the same cluster in a 95....the gas guage didn't work, but i don't know if the car has problems or my ls cluster..i just need aanother car to test in..
949eg
May 29, 2003 11:34 PM
