reprogram ECU? you've got to read this sh*t
Old Jan 8, 2003 | 11:44 AM
94ls's Avatar
Default reprogram ECU? you've got to read this sh*t
for all the N/A modified tegs out there, I just saws omething from someone that I wanna ask if it's true or if anyone has heard of this?????? I mean, what the **** is this about............ Modifying your Integra
Index of this page
How Tos | Integra Stuff | Who to Get Stuff From
How Tos
Reading these 'How Tos' will help you understand how your car works.
Carrying out certain of these 'How Tos' may void your insurance, break the law, and make your car a danger to yourself and others. Always talk to your insurance company and an experienced mechanic before carrying out such work. Should you attempt any of these 'How Tos', you do so at your own risk. Eireann.org takes no responsibility.
1. How to make a Short Shifter.
Five quick steps to a quick shift lever. Quick shift gear levers are very easy to make for the 3rd generation Integra.
Download Details: MS Word Format, 624 KB
By Dublin based GX, Jan 2002.
2. Reprogramming the ECU into giving you better economy and smoother engine response after an upgrade.
After you get a performance upgrade (i.e. exhaust, intake etc.) take the following steps to reprogram your computer:
Turn on the car and warm it up (make sure that it is at normal idle).
Turn off the car and pull out your ECU fuse located in the fuse box under the bonnet (this is usually a 15 amp fuse found right near the bulkhead).
Keep fuse out for at least 5 to 10 minutes.
Plug fuse back in and close bonnet.
Start your car MAKING SURE NOT TO TOUCH THE ACCELERATOR WHEN YOU START IT UP.
Let the car idle (at its normal idle) for about 5 minutes.
Shut off the car and restart it. Take it for a test drive and you should notice the difference.
That's it! Your ECU is originally programmed to mix optimal amounts of air and petrol for a factory spec car (no modifications). By taking out the fuse you kill all power to your computer, therefore resetting the 'program' that gives you the right mixture. Now by NOT TOUCHING THE ACCELERATOR as you fire it back up, the ECU will reprogram itself to give you the best MPG possible based on your current set-up.
Old Jan 8, 2003 | 11:50 AM
216.226.142.95:27016's Avatar
Default Re: reprogram ECU? you've got to read this sh*t (94ls)
i think this is more of reseting your ecu rather than reprogramming it
Old Jan 8, 2003 | 11:52 AM
Eva01's Avatar
Well, this is not technically reprogramming your ECU since your not really going to change the parameters of the ECU such as redline and vtec crossover ect. It's more of less just resetting the ECU and letting it "learn" how to work optimally with the modifications such as a new intake or exaust that has been installed. Even without resetting the ECU the computer will eventually find the best program to run but resetting is just a quick way for the ECU to acclimate itself to the a new mod.
PM-Performance's Avatar
Default Re: reprogram ECU? you've got to read this sh*t (216.226.142.95:27016)
yea its just resetting it , i have heard of that ,but never found it worth doing becuase i never noticed and kind of change.
Old Jan 8, 2003 | 11:56 AM
Audio28's Avatar
Default Re: reprogram ECU? you've got to read this sh*t (itr206)
yeah, you could also pull out your ground wire. i've heard about it, but never did it. has anyone done this yet?
Old Jan 8, 2003 | 12:22 PM
Caffeine Slug's Avatar
Default Re: reprogram ECU? you've got to read this sh*t (Audio28)
If they're still around in an archive somewhere, go back to posts in this forum from about 2 years ago. Just about every single thread on installing an intake had a half dozen people saying "don't forget to reset your ecu!". Now it never gets mentioned at all. it's not a big deal.
Old Jan 8, 2003 | 01:49 PM
Evilteg's Avatar
Default Re: reprogram ECU? you've got to read this sh*t (Caffeine Slug)
is true, its kinda common sense.
tinctorus
Nov 19, 2010 09:49 AM
efyou
Sep 22, 2005 03:35 PM
pane93civhb
Aug 7, 2004 08:51 AM
JICsube
May 30, 2002 04:16 AM
SEIKI
Jan 19, 2002 10:48 AM
