ITR crank pulley and plate. Help (did search)
Old Jan 8, 2003 | 02:45 AM
pinota's Avatar
Default ITR crank pulley (timing belt ) and plate. Help (did search)
Hello,
In a B18C1 crank it has a pulley ( for the timing belt ) with a sensor, whatīs that sensor ?
Can the B18C1 crank it be used on a ITR but with the type R pulley ( timing belt )without sensor ?
Thanks.
Pinota
[Modified by pinota, 12:00 PM 1/8/2003]
Old Jan 8, 2003 | 03:28 AM
Benny Hinn's Avatar
Default Re: ITR crank pulley (pinota)
crank fluctuation sensor
Old Jan 8, 2003 | 05:52 AM
FSTASNTZ's Avatar
Default Re: ITR crank pulley (Benny Hinn)
Correct me if I am wrong. The only time you need that sensor, is if you are running an ECU that is looking for it. Converting a 1997+ to a 1992-1995 P28 would eliminate the use for that sensor. Thus meaning you can remove it.
As for the C1 crank in the C5 block with the C5 pulley and no sensor, should be just fine, as long as the ECU you are using does not look for that sensor.
Anyone, correct me if I am wrong.
Jason
Old Jan 8, 2003 | 06:02 AM
BERT-O's Avatar
Default Re: ITR crank pulley (FSTASNTZ)
Jason
You are correct, if your using a OBD-1 program, you won't need the crank sensor.
Old Jan 8, 2003 | 08:57 AM
Benny Hinn's Avatar
Just make sure that the lower timing belt cover matches the oil pump. The 94-95 GSR lower cover will not fit a 96 up b series oil pump due to the mount points for the CKF.
Old Jan 8, 2003 | 11:16 AM
pinota's Avatar
I have a 98 ITR. Do you think i will not use the crank fluctuation sensor ?
The crank thatīs on the B18C6 block is diferente from the B18C1 crank.
Does USDM spec ITRīs need this sensor ?
I have a euro spec 98 R.
[Modified by pinota, 8:18 PM 1/8/2003]
Old Jan 8, 2003 | 11:18 AM
sgT's Avatar
sgT
if it was on your motor before, USE IT.
Natie Barnard
Honda CR-V & Element
Jan 16, 2019 06:38 AM
kndj30
Honda Civic (2001 - 2005)
Feb 11, 2010 03:58 AM
rotten
Sep 25, 2005 06:18 PM
Kp_VtekNiks
Apr 11, 2002 09:44 AM
