What substance is pure ammonia?? to take my tint off.
Old Jan 7, 2003 | 12:53 PM
IdotheSHOCKER's Avatar
Default What substance is pure ammonia?? to take my tint off.
Ummm I know Windex glass cleaner has ammonia in it but what substance is pure and stronger so that I can remove this ugly bubble tint !!!
Something that I can pick up at the grocery store preferrably.
Old Jan 7, 2003 | 12:57 PM
BlackAxis's Avatar
Default Re: What substance is pure ammonia?? to take my tint off. (EGB18hatch)
Why don't you pick up some AMMONIA at the grocery store?
You won't find pure ammonia unless you seek out a chemical supplier (like for labratories, but you don't need it anyway.
Old Jan 7, 2003 | 01:07 PM
greebler's Avatar
Find a street cat from a local alley, make it pee in a container. Cat pee is mostly ammonia and will take off pretty much anything. Just don't get it on your skin for it will eat through it in about a min.
[Modified by greebler, 10:07 PM 1/7/2003]
Motorhead
Guest
Posts: n/a
Use GooGone(brandname) & a razorblade.Wipe on alot & the adhesive will come off very easy with the blade.You can get GooGone at most grocery stores/HomeDepots etc.
Old Jan 7, 2003 | 01:09 PM
Motorhead
Guest
Posts: n/a
Default Re: What substance is pure ammonia?? to take my tint off. (greebler)
Yeah & your car will smell like cat **** forever.
Old Jan 7, 2003 | 01:23 PM
SpooN Man's Avatar
Default Re: What substance is pure ammonia?? to take my tint off. (BlackAxis)
DERF
Old Jan 7, 2003 | 01:33 PM
LazYRaCeR's Avatar
Default Re: What substance is pure ammonia?? to take my tint off. (Motorhead)
the way i took off my tint, was I took a razor, and scraped all the tint off, (once you get the hang of it, it goes pretty quick), I took all the glue off by using a small rag, and putting rubbing alchohol on it, and just wiping off the glue, just put some pressure on it, and the glue comes right off... hope it helped...
Old Jan 7, 2003 | 01:35 PM
underrated99si's Avatar
rip as much as u can off then get a a razorblade hold it flat to the window to take off the adhesive just spray any kind of window cleaner or just soap and water thats all u need worked for me
Old Jan 7, 2003 | 03:22 PM
variable's Avatar
Default Re: What substance is pure ammonia?? to take my tint off. (underrated99si)
Also walmart has a product called tint-off that is high concentarte amonia $5 works well with a razor
Old Jan 7, 2003 | 03:47 PM
EVIL Hx Coupe's Avatar
Default Re: What substance is pure ammonia?? to take my tint off. (variable)
I've tryed this, and it works really good.
Old Jan 7, 2003 | 04:47 PM
tominos's Avatar
Default Re: What substance is pure ammonia?? to take my tint off. (Boost Pressure)
yea most auto places that carry tint, sells products to remove tint.
Old Jan 7, 2003 | 04:50 PM
SIMATIC's Avatar
Default Re: What substance is pure ammonia?? to take my tint off. (tominos)
Will the ammonia eat through the rear defroster? i wana to remove my purple tints. They used to be black a few yrs ago
Old Jan 7, 2003 | 07:41 PM
ryanhook's Avatar
Jeezuz... I can't believe how often the same issues appear over and over again. If you searched you'd come across a complete tutorial I typed up on this exact issue only a few months ago.
Go to the local hardware store (not Home Depot, Loews but True Value or some mom & pop place) and buy some ammonia. Also pick up some razor blades, 0000 or 000 steel wool (use on the back window), black garbage bags, rubber gloves, face mask (to prevent inhaling ammonia fumes) and some safety goggles.
Then find my post and follow the instructions: https://honda-tech.com/zerothread?id=313871 or here https://honda-tech.com/zerothread?id=198449
[Modified by ryanhook, 11:44 PM 1/7/2003]
Old Jan 7, 2003 | 08:32 PM
dwnthehatch's Avatar
GOOD STUFF!!!
JuanK20
Jan 30, 2005 07:51 PM
OneThirtyEight
Feb 24, 2002 06:59 AM
xXreaperXx
Jan 16, 2002 12:46 PM
