itr lsd?
Old Jan 7, 2003 | 10:46 AM
SupaTeg's Avatar
Default itr lsd?
Can an ITR lsd fit an ls??
Old Jan 7, 2003 | 10:49 AM
NeoGSR's Avatar
Default Re: itr lsd? (SupaTeg)
i believe any b-series tranny will bolt up to any b-series engine....i'm planning on doing this too w/ my GSR...
Old Jan 7, 2003 | 11:10 AM
SupaTeg's Avatar
Default Re: itr lsd? (NeoGSR)
I'm not talking about the whole tranny just the LSD
Old Jan 7, 2003 | 12:22 PM
Tigger's Avatar
I believe it should. I put ITR internals, including the LSD into my LS case. So I don't see why the LSD wouldn't fit. The diffs should be the same size, the only difference being the internals of the diff.
Old Jan 7, 2003 | 12:32 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: itr lsd? (Tigger)
Do a search on this. I answered this a couple times already.
Anywho...the ITR LSD won't fit in directly. You need a 4.400 final drive ring gear from another b-series tranny that has a 4.400 final drive. (GSR, ITR, B16) Besides that, you also need the countershaft from a 4.400 tranny as well.
Keep in mind that even though the 4.266 LS final drive ring gear and countershaft idle gear have the same number of teeth as it's 4.400 counterpart, it won't work due to slight differences in tolerances.
Just look around for the ring gear and countershaft in classifieds. I got my countershaft for $75 here on HT. The ring gear I had lying around. I bought the ITR LSD off of Ebay.
Good luck.
xzodiackillerx
Transmission & Drivetrain
Feb 6, 2012 08:40 PM
SupaFly_Honda
May 12, 2004 05:12 AM
sirminder
Sep 5, 2003 11:34 AM
p1ccoloz
Mar 15, 2003 08:21 PM
tmkpres
Jan 9, 2003 10:08 AM
