Home made camber kit?
yeah i was wondering how to make my own camber kit, its for a friend of mines his tires in the back are gay as s faw* things like slanted way off , but yeah help me out what size the bolt are i remember reading it on of someones thread about those homemade camber kit but yeah its going to be on a 96 EK so help me out guys
Homemade camber kit? Yea, it's called RAISE THE SUCKER BACK UP!
How low of a drop?
And if you have $$$ to spend on tires monthly (due to camber wear), you can definitely afford a simple camber kit. I bet you he never had it aligned properly after the lowering too huh? Cheapskates...
How low of a drop?
You use washers to shim the upper control arm outward. If the camber is really off, you'll need longer bolts for the arm and a lot of washers. The results from this can work just as good as any kit on the market.
http://www.geocities.com/lx98civic , found this on an earlier post. This should be helpful.
