those w/ test pipes
Old Jan 5, 2003 | 01:36 PM
wildstallion's Avatar
Default those w/ test pipes
how much did they cost you??? did you go to a local muffler shop to get it made??? and what did you do w/ the o2 sensors?????
Old Jan 5, 2003 | 02:15 PM
del_parker's Avatar
Default Re: those w/ test pipes (wildstallion)
testpipe.com
Old Jan 5, 2003 | 03:23 PM
Cottonwoodz's Avatar
Powercore make a really nice one for about $130.00
<U>http://www.landspeedracing.com/shopping/ProductList.asp</U>
Old Jan 5, 2003 | 03:25 PM
Nevermide, you got a 5th Gen
Old Jan 5, 2003 | 03:39 PM
BolivianFuego's Avatar
Default Re: those w/ test pipes (Cottonwoodz)
Get one, you really feel the difference, and since you got a 5th gen, do the obd II work around, you could find out where to do this at http://www.ntpog.org. I use a test pipe,and obd II workaround and i never through codes.
Old Jan 6, 2003 | 06:26 PM
91cvcsi's Avatar
I have a '96 and i found one on ebay for like forty some bucks. Even though it was cheap i tried it anyways and it worked out great, pulls a lot harder and sounds a **** load better than a gutted cat. It did come with two o2 sensor holes so I found and old one and screwed it in and cut the wire off. I hooked the other right up, but you'll probably never get rid of your engine check light.
Old Jan 6, 2003 | 06:32 PM
BoostedH23a1's Avatar
Default Re: those w/ test pipes (91cvcsi)
lot louder.
Old Jan 7, 2003 | 11:20 AM
s13_240sx_92's Avatar
You can get a secondary O2 sim or make your own. They are out there. You don't want to run around with a CEL. Good Luck and save the planet
bigz187
Mar 26, 2010 01:06 PM
Variable J
May 17, 2004 06:40 AM
EKB18BPR3
Jul 7, 2003 10:50 AM
Nfurno
Feb 4, 2002 06:24 PM
Ri5e
Aug 14, 2001 03:45 PM
