95 Integra - Interior water leak
My 95 Integra seems to have sprung a leak. Water is somehow leaking in, near the gas / brake pedals. I believe its actually coming in somewhere near the kick panel below the fuses. The seal around the door is fine. The sunroof, no problem. I'm not sure if there is some sort of drainage thats clogged up or not. Anyone have any ideas?
When you say that the sunroof is not leaking, did you mean the sunroof drain? I had a leak that ended up being the drain had popped off and it was draining into the car. double check and make sure the water is draining out behind the front wheels.
where exactly are the front and rear drain hoses -i'd like to air-gun mine out. from the bottom and flush at all back up to the top
JDMx05
Sep 10, 2011 08:02 PM
wambus
11
Mar 24, 2003 07:52 AM
