How do u determine what color rod bearings go on top or the bottom for Eagle rods ??
I am putting my motor together and I am trying to find out what bearing color (green / brown) goes on top or the bottom... Cause the Eagle rods are #24 .... thanks
not sure what your asking...on top or bottom of what?
rods are #24..what do you mean?
Are the rods new? Do you know the size of the rod journals on the crank?
If rods are new then they should be standard size...48.0mm(1.89in)
Just need to know rod journal diameter to help you better. Standard is: 44.976-45.000mm(1.7707-1.7717in) HTH
baonest1
May 31, 2003 04:35 AM
SpoonFed
Jan 4, 2003 05:24 PM
civicguy
Mar 29, 2002 04:56 AM
