450cc DSMs on a 5G Lude?
Old Jan 4, 2003 | 09:35 AM
BlueShadow's Avatar
Default 450cc DSMs on a 5G Lude?
Hi guys,
I was wondering if anyone knows how hard it would be to install a set of 450cc DSM injectors? I wanted to know if I needed to modify the injectors or fuel rail in order to get them to fit.
thanks
Old Jan 4, 2003 | 10:31 AM
BlueShadow's Avatar
Default Re: 450cc DSMs on a 5G Lude? (BlueShadow)
ttt
Old Jan 4, 2003 | 10:53 AM
bb6h22a's Avatar
I cant remember if you can fit them on the fuel rail, but I do know that you'll have to run a resistor box, and different ECU as DSM injectors, if i recall, are peak and hold, not saturated like the obd2 h22 injectors. You may want to consider using obd 1 h22 injectors as they flow more than the obd2's and fit the fuel rail, guranteed.
Old Jan 4, 2003 | 11:04 AM
BlueShadow's Avatar
Default Re: 450cc DSMs on a 5G Lude? (bb6h22a)
Thanks but I already know about needing resistors with any peak and hold injectors on my 01 Lude. The injectors will be used with an AEM EMS which IIRC have saturated drivers, so I am aleady planning on wiring in some resistors so I dont fry the EMS.
If you notice my sig, you'll see that I intend to turbo soon, so I will need bigger injectors. I dont really want to go with injectors like RC or MSD because a set of 4 is too expensive.
Old Jan 4, 2003 | 12:06 PM
LJR-LUDE01's Avatar
I got some of those and from all the research I have done they should be good.. some people just use a dremal bid to shave off on the oring I think just enough to get the injector nice and tight... the fuel rail should be no problem.... and ofcousr you already know about the resistor thing... are you using the 10ohm resistors of you gettting an old resistor box...? hope the helps...
Old Jan 4, 2003 | 12:12 PM
BlueShadow's Avatar
Default Re: 450cc DSMs on a 5G Lude? (LJR-LUDE01)
...are you using the 10ohm resistors of you gettting an old resistor box...? hope the helps...
thanks for the info, as far as the resistors go, I was thinking about contacting Sonny to get the resistors whenever I am ready.
Old Jan 4, 2003 | 01:37 PM
LJR-LUDE01's Avatar
yeha last time I check he still had 5 esistor boxes left... there enough junk yards in Miami so I'll find one I'm pretty sure ... when are you installing your kit?
Old Jan 4, 2003 | 01:45 PM
BlueShadow's Avatar
I might start looking in a few junkyards myself or maybe I can find a DSM owner on http://www.dsmtalk.com that doesn't want their injectors. Right now I'm still missing a few key components, but I hope to have everything soon. I expect to start installing stuff a month and a half from now, maybe longer if I have to buy stuff new.
Old Jan 4, 2003 | 08:21 PM
DLB1994's Avatar
if you want some i got some that been cleaned and flow tested by RC
i had them in my car for about 4,000 miles am going to 720cc's with my new setup
Old Jan 4, 2003 | 08:23 PM
BlueShadow's Avatar
Default Re: 450cc DSMs on a 5G Lude? (DLB1994)
IM'ed you
Old Jan 6, 2003 | 12:16 AM
BlueShadow's Avatar
One other question I had for you guys:
will the Prelude clips work with the 450's or will I need a different set of clips?
thanks
Old Jan 6, 2003 | 12:26 AM
sharkcohen's Avatar
Your stock clips will not work. You will have to cut them off and solder on the correct clips.
Old Jan 6, 2003 | 12:27 AM
BlueShadow's Avatar
Default Re: 450cc DSMs on a 5G Lude? (sharkcohen)
which ones are the correct ones?
Old Jan 6, 2003 | 12:35 AM
sharkcohen's Avatar
For DSM 450s I do not know, but I'm sure someone around here does. I think you can get the right clips from RC.
[Modified by sharkcohen, 9:36 AM 1/6/2003]
Old Jan 6, 2003 | 01:39 AM
safe driver's Avatar
you can use clips from obd1 cars. i got clips from obd1 mazda, mitsu, and honda to work. i think i still have a few sets laying around. i was selling them a while ago for dirt cheap. IM me if you want a set. i also have resistor boxes too. i sold them for a lot cheaper than some other person on F-I board
Old Jan 6, 2003 | 11:49 AM
DLB1994's Avatar
Default Re: 450cc DSMs on a 5G Lude? (safe driver)
MyF20b_Prelude
May 30, 2015 08:43 PM
kornerk12
Sep 21, 2006 09:17 AM
ridnmyhonda
Mar 18, 2003 06:24 AM
