sluggish lag STILL!!
Old Jan 4, 2003 | 05:58 AM
BigChris's Avatar
Default sluggish lag STILL!!
Hey guys, what's up?? First off wanna wish everyone a happy new year!!!
I don't know if anyone remembers about my post from a month or so back about my lag. I have a 94 accord with h22a 5spd and I"m getting lag right upto VTEC. When VTEC kicks in, it moves. I was told to change the O2 sensor so I did. Unfortunately I'm still having the same problem. Anyone have any other clues as to what else I can do..
Old Jan 4, 2003 | 07:59 AM
KTeller8's Avatar
Default Re: sluggish lag STILL!! (BigChris)
what are some of your mods? what ecu you have
do a quick refresh (cliff notes) of your set up and what your running
Old Jan 4, 2003 | 08:14 AM
BigChris's Avatar
Default Re: sluggish lag STILL!! (KTeller8)
JDM H22a
Short Ram Intake
DC Headers
Greddy SP Exhaust
No Cat
Clutch/Flywheel
Stock ECU
Old Jan 4, 2003 | 09:04 AM
KTeller8's Avatar
[QUOTE what ecu you have
[/QUOTE]
Old Jan 4, 2003 | 09:27 AM
97accordex's Avatar
1. Make sure oil and plugs are OK.
2. Check distributor cap, make sure its tight and that it has not rotated. A new rotor, wires and plugs would not hurt.
3. Check ignition/valve timing, maybe rotate distributor a bit or if you have adjustable cam gears advance a bit. The idea here is to shift the power band so that you have some power down low.
4. Make sure that your injectors are clean and free flowing. (hard to check without removing)
Based on the limited amount of info, these are the least invasive things to check if you have not already checked them.
Old Jan 6, 2003 | 05:17 PM
AccordVtec's Avatar
I had the same thing. Mine was only once the car was fully warmed up though.
It end up being that my ditributre was rotated a little retarded.
It was becuase we when did the timing, we just used the timing light to check the engine and it was good. I guess we didnt let the engine run long enough though.....
So give that a try, move the distributer all the way towards the firewall (Up and Back)
Let me know what happens
Accord VTEC
Old Jan 6, 2003 | 05:24 PM
urbanlegend21's Avatar
New User
Default Re: sluggish lag STILL!! (AccordVtec)
your timing would be my best bet also
Old Jan 6, 2003 | 09:31 PM
BigChris's Avatar
will definitely try it out tomorrow
Old Jan 10, 2003 | 04:51 PM
BigChris's Avatar
NO MORE LAG!!! AccordVtec, you hit it on the spot. I adjusted my distributor and it was gone.. I love my H22 now. LOL. thanks alot man
Old Jan 10, 2003 | 05:10 PM
BoostedH23a1's Avatar
i was just about to say its for sure your timing.
Old Jan 11, 2003 | 08:38 AM
GZERO's Avatar
now go and fix that signature
Old Jan 11, 2003 | 09:24 AM
BigChris's Avatar
Default Re: sluggish lag STILL!! (GZERO)
fixed!
Old Jan 11, 2003 | 10:12 AM
97accordex's Avatar
Default Re: sluggish lag STILL!! (BoostedH23a1)
Hey boosted dude,,,,,,,,,
I like the sig,,,,,,,,,,,,,,,,,, criticize is spelled wrong though. I don't have your shoes but I am way over a mile away,,,,,,,,,,,,
Old Jan 11, 2003 | 10:44 AM
GZERO's Avatar
Default Re: sluggish lag STILL!! (97accordex)
LMAO!!!!
98luda
Jul 15, 2012 11:43 PM
702accord
Nov 18, 2009 08:05 PM
EsQueue
May 2, 2004 04:33 PM
gvillehnut
Feb 4, 2003 08:14 AM
