JDM Type R Motor..Compression?
Just wondering what the compression should check out to be around on a JDM type R motor. Im having a shop do a compression check on the motor so I need to know what it should be around. Thanks
The most important thing is to have similar compression numbers on all four cylinders.
A lot of variables will affect the numbers but I guess that anything between 210 psi to 240 psi should be good results
