GSR crankshaft with gsr pistons/rods in a b18a block?
Old Jan 2, 2003 | 10:50 PM
crxtreme27's Avatar
Default GSR crankshaft with gsr pistons/rods in a b18a block?
I already searched but cant find anything on this topic... I was wondering if i can use the GSR crankshaft, pistons & rods in a 91 B18A block for LS VTEC... Is it possible?? Is it even worth it?? would i be able to rev up to 8200 rpm??? or should i just keep the LS crankshaft and rods with PR3 pistons and ARP rod bolts???
Old Jan 3, 2003 | 01:01 AM
Kwuaymaikrup's Avatar
Default Re: GSR crankshaft with gsr pistons/rods in a b18a block? (crxtreme27)
It's pointless to do that if you wanna go ls/vtec. The main reason people do the ls/vtec swap is to gain displacement/torque from the ls bottom end. If you swap all that you essentially have a GS-R motor without the oil squirters, girdle and higher output oil pump. IMO not worth it unless you want a GS-R and can't find a block.
Good luck.
Ryan
[Modified by Kwuaymaikrup, 2:01 AM 1/3/2003]
killerB16A
Northwest (Sales)
Apr 29, 2009 08:40 PM
98GSR-Turbo
Oct 14, 2008 09:22 AM
truteg801
Oct 27, 2005 05:15 AM
tnsxsear1
Feb 8, 2004 03:33 PM
crxtreme27
Jan 13, 2003 07:59 AM
