GSR crankshaft and Pistons/rods in a b18a block??
Old Jan 2, 2003 | 10:41 PM
crxtreme27's Avatar
Default GSR crankshaft and Pistons/rods in a b18a block??
I already searched but cant find anything on this topic... I was wondering if i can use the GSR crankshaft, pistons & rods in a 91 B18A block for LS VTEC... Is it possible?? Is it even worth it?? would i be able to rev up to 8200 rpm??? or should i just keep the LS rods with PR3 pistons and ARP rod bolts???
[Modified by crxtreme27, 11:42 PM 1/2/2003]
Old Jan 3, 2003 | 01:48 PM
Lsos's Avatar
Default Re: GSR crankshaft and Pistons/rods in a b18a block?? (crxtreme27)
I'm pretty sure they wouldn't fit unless you used shorter rods.
Old Jan 11, 2003 | 05:03 PM
hybrid901's Avatar
Default Re: GSR crankshaft and Pistons/rods in a b18a block?? (Lsos)
You can use a gsr crank and rods in a ls but why would you want to? The whoel point of teh LS/Vtec is the extra displacement.
Old Jan 11, 2003 | 05:22 PM
racecarpete's Avatar
by doing this, you will in fact be DEstroking the motor, this defeats the purpose of doing LS/VTEC.
Old Jan 13, 2003 | 07:59 AM
Wes V's Avatar
Default Re: GSR crankshaft and Pistons/rods in a b18a block?? (SilverCivic2k)
Although there are certain reasons for not doing this, I'd also like to know how much of the "internals" from a GSR could be put in a B18A.
One reason (at least it's why I'm interested) has to be with legality and the idea of building a "sleeper". Think about this;
If it's a "B18A", then you can run OBD0. Thus you can use the Zdyne Gold ECU that is programable on the fly. (the Hondata requires a new prom to be burned or emulater used during tuning) Another "bonus" of the Zdyne is that you can set it up so that it appears "unmodified".
Heck, I'd even go so far as to run the LS valve covers just so that they don't say VTEC on them. Although a Referee station would (should) be able to tell if the head is a VTEC or not, I'd bet that a smog check station wouldn't know.
If you used a Skunk2 intake manifold, it would also help in making an engine that "looks" like a stock LS.
Wes
dirtyharryhatch
10
Jul 21, 2009 02:43 PM
EFin' Kyle
Sep 22, 2004 04:19 PM
slimcivic95
Aug 31, 2004 07:01 PM
crxtreme27
Jan 3, 2003 01:01 AM
Quicky
Nov 25, 2002 05:12 PM
