B18c+Rev hard stage2c turbo..... What electronics and gadgets????
Old Jan 2, 2003 | 07:52 PM
mitchb's Avatar
Default B18c+Rev hard stage2c turbo..... What electronics and gadgets????
Ok ive finally figured out exactly what im gonna do. Now i need to know what all electronics and gadgets i need to make it work right and be able to tune and moniter. Prices would be nice too. Thanks
Old Jan 2, 2003 | 08:33 PM
EpDarks's Avatar
Default Re: B18c+Rev hard stage2c turbo..... What electronics and gadgets???? (mitchb)
Depends on how far you want to go with it...
Engine management like Hondata or AEM EMS are the best route, unfortunatly they are expensive, and tricky to learn.
If you only want moderate boost levels, a V-AFC should do the trick. Don't forget about the cam gears and the FPR too. Boost guage, and some way to monitor your A/F easily.
Good luck.
Old Jan 2, 2003 | 11:19 PM
I Like Boost's Avatar
Default Re: B18c+Rev hard stage2c turbo..... What electronics and gadgets???? (EpDarks)
is the engine stock or built, if it's built i would get some type of engine management (hondata or AEM EMS) whichever is easier for you to get tuned. boost controller is a must, turbo timer if you are lazy. boost, egt, oil temp/pressure gauges are nice to have. thats all i can think of right now its kinda late.
Old Jan 3, 2003 | 04:31 AM
mitchb's Avatar
Default Re: B18c+Rev hard stage2c turbo..... What electronics and gadgets???? (BEe18SeAONe)
THe engine is going to be bone stock, until about early summer then i am gonna build it and go with new fuel and ignition. I will go with a standalone then. As far as the gauges, timers and controllers what kind of brand do you guys recommend?
GT500FTW
May 7, 2013 09:55 AM
H22civatch
Jun 15, 2005 07:48 PM
VTcivicEG
Jul 18, 2004 04:31 PM
maxxd97
Oct 7, 2003 05:19 PM
Racer X
Oct 16, 2002 08:59 PM
