Is it safe to add ES motor mount inserts on WORN OUT mounts instead of replacing them and addings th
Old Jan 2, 2003 | 04:32 PM
Rratedcivichatch's Avatar
Default Is it safe to add ES motor mount inserts on WORN OUT mounts instead of replacing them and addings th
what the title says... i have worn out mounts....should i replace them with new ones and then put the es inserts on or just put the inserts on because es says you can do that. thanks
Old Jan 2, 2003 | 05:29 PM
Default Re: Is it safe to add ES motor mount inserts on WORN OUT mounts instead of replacing them and adding
ttt
Old Jan 2, 2003 | 05:36 PM
chad's Avatar
Moderator
don't do a ttt WHEN THE POST IS ONLY 1 HOUR AND 30 MINUTES OLD people in this forum know you need to check the second page!!!!
Old Jan 2, 2003 | 06:02 PM
Patrick's Avatar
Ok, forum ****.
Yeah, just throw those es bushings in there and youll be fine.
Old Jan 3, 2003 | 12:42 AM
chad's Avatar
Moderator
****......hahaha
get new mounts to be on the safe side....i'll gladly sell you a set
Old Jan 3, 2003 | 01:09 AM
is it safe to run worn mounts with the inserts?
Old Jan 3, 2003 | 01:21 AM
civura R's Avatar
i have a broken upper drivers mount i just put inserts in the bottom 2 mounts and it is fine i have a new mount for the top just been lazy
Old Jan 3, 2003 | 11:30 AM
which mount usually wears out the fastest , the drivers side? i know you can put the inserts and not change the mount but how safe is it and how long would it last like that? do they say you can use them on worn mounts because the urethane insert goes in place of the rubber? please help
Old Jan 3, 2003 | 11:40 AM
Rob Dizzle's Avatar
I would get new ones if you can afford them
you could have more wheel hop if your mounts are worn...
Old Jan 3, 2003 | 11:44 AM
if my mounts are worn and i put on the inserts, i hear that it makes everything solid. so it is kinda like gettin a new motor mount with urethane?
Old Jan 3, 2003 | 01:02 PM
Mojo-Jojo's Avatar
Okay, since I've actually DONE this I'll chime in...
https://honda-tech.com/zerothread?id=339020
It's fine. You don't need new mounts.
Three of the four rubber bits on my left lower mount were totally torn. The right mount was really weak and loose. The ES mount fills in all the airspace between the little rubbery bits between the frame of the mount and the mounting shafty bit from the engine.
There is a little more vibration than there used to be, but it's fine. I doubt there is any more wheelhop now than there would be if I did new stock mounts + ES inserts.
It would be pointless to get new stock ones.
Old Jan 3, 2003 | 04:41 PM
your info was most helpful. you have a PM from me. i would just like to know what part # i would be looking at getting? i have a 95 cx hatchback with a b series swap. do i get just 3 or all 5? thanks
lude98SH
Jul 8, 2007 08:34 AM
dreams190
Feb 11, 2006 05:28 PM
rocketfuelcerx
Apr 8, 2005 11:53 AM
Brewer
Mar 23, 2004 07:30 PM
DJ_SaNdOz
Feb 10, 2003 09:10 AM
