Is it safe to add ES motor mount inserts on WORN OUT mounts instead of replacing them and addings th
what the title says... i have worn out mounts....should i replace them with new ones and then put the es inserts on or just put the inserts on because es says you can do that. thanks
Moderator
Re: Is it safe to add ES motor mount inserts on WORN OUT mounts instead of replacing them and adding
don't do a ttt WHEN THE POST IS ONLY 1 HOUR AND 30 MINUTES OLD people in this forum know you need to check the second page!!!!
Yeah, just throw those es bushings in there and youll be fine.
Moderator
****......hahaha
get new mounts to be on the safe side....i'll gladly sell you a set
i have a broken upper drivers mount i just put inserts in the bottom 2 mounts and it is fine i have a new mount for the top just been lazy
which mount usually wears out the fastest , the drivers side? i know you can put the inserts and not change the mount but how safe is it and how long would it last like that? do they say you can use them on worn mounts because the urethane insert goes in place of the rubber? please help
I would get new ones if you can afford them
you could have more wheel hop if your mounts are worn...
Okay, since I've actually DONE this I'll chime in...
https://honda-tech.com/zerothread?id=339020
It's fine. You don't need new mounts.
Three of the four rubber bits on my left lower mount were totally torn. The right mount was really weak and loose. The ES mount fills in all the airspace between the little rubbery bits between the frame of the mount and the mounting shafty bit from the engine.
There is a little more vibration than there used to be, but it's fine. I doubt there is any more wheelhop now than there would be if I did new stock mounts + ES inserts.
It would be pointless to get new stock ones.
your info was most helpful. you have a PM from me. i would just like to know what part # i would be looking at getting? i have a 95 cx hatchback with a b series swap. do i get just 3 or all 5? thanks
Brewer
03-23-2004 07:30 PM
