my trani has problems!! HELP
well its got one big problem. it has no splines inside the trani. there gone and fallen into the bottom of the trani.
u guys ever heard of this? should i just get a new trani or try to see if it just kinda fell out? lol
no it should just fall off, unless some doodoo head decided it needed to be sealed, which it doesn't...just make sure you've got all the bolts uunscrewed and if you have to try using a flathead screwdriver and pry it off gently
if you took all the bolts out on top , check underneath for more. There is another bolt that looks like its not connected to the tranny but it does connect into the tranny (near the rear mount bracket)
Some time its caked on, remember the input shaft is going into the engine so you'll have to pull outwards horizontally. One time I had one caked on so bad I had to pry it open with a flat head, it popped right off after the screwdriver fit in.
ten to one says he forgot the bolt that goes from the drivers side through the block to the trans
ok this is driving me to insanity
i have checked and re checked every spot for a dam bolt. NO LUCK
it feels like its being held on the bottom cause the top part is coming off..
WHAT THE ****
WHAT THE ****
got it!
front alignment pin was stuck like a mother ******..
lol my trani has stuff rattling around inside
time to open it up and see what the hell hapened.
doublethink
Sep 13, 2007 02:35 PM
admess188
Feb 2, 2007 06:49 AM
AshlandSi
Oct 15, 2001 06:55 PM
