Help!!!!! Clutch....
Hey guy I'm in deep need of help. I don't know what is wrong with my clutch. Whenever I turn off my car I could shift into each and every gear. But sometime when the car is turn on, I can't put it into any gear. So now I'm wondering if my clutch is worn out? The tranny fluid need more fluid? Need an oil change? HElp Plz
Hey guy..What if the problem is not on the bleeding clutch..What if it something else? Because sometime I come to a stop and then try to put it into gear..it won't go into any gear..Unless I turn off the car then turn it back on..n now I could put it into gear.
Listen..we are not saying that is THE probelm..
If you can not get your car into gear..maybe the clutch isnt disengaging fully. Therefore it could be you need to bleed your clutch.
We are trying to rule out the simple things and help you dude.
It could be a bad master cylinder, which most tegs seem to have at one time or another. Look and see if your clutch resevoir is low on fluid. Also look for leakage where your where the clutch rod goes into firewall. If you see fluid leaking there that is an indication that the master cylinder has gone bad.
How many miles do you have on the clutch. It could be going out. Symptoms of a bad clutch are things such as: clutch chatter, mushy or light pedal feel, difficulty in getting in and out of gear, clutch slippage...If it's under warrenty have the dealer look at it.
HTH
HTH
hehe thanks for the answer guy...I think it my clutch going out now..because the pedal feel musy and shatter sometime and it hard to shift in between gear..It like I have to force it..and everytime I start off first gear..it feel like it want to stall..So thanks guy..Now I want to know how much would it cost to get a new clutch install?? any ideas? and no the car is not under warrenty..
just4747
28
Dec 5, 2004 11:30 AM
