Help!!!!! Clutch....
Old Jan 2, 2003 | 12:35 PM
djtony5's Avatar
Default Help!!!!! Clutch....
Hey guy I'm in deep need of help. I don't know what is wrong with my clutch. Whenever I turn off my car I could shift into each and every gear. But sometime when the car is turn on, I can't put it into any gear. So now I'm wondering if my clutch is worn out? The tranny fluid need more fluid? Need an oil change? HElp Plz
Old Jan 2, 2003 | 12:37 PM
ragejed's Avatar
Default Re: Help!!!!! Clutch.... (djtony5)
How about you bleed your clutch..see where that gets you.
Old Jan 2, 2003 | 12:53 PM
djtony5's Avatar
Default Re: Help!!!!! Clutch.... (ragejed)
If that would be the problem then how would you bleed your clutch? Because I've never done that before..Thanks
Old Jan 2, 2003 | 01:04 PM
Eva01's Avatar
Here's a link: https://honda-tech.com/zerothread?id=309481
Old Jan 2, 2003 | 01:44 PM
djtony5's Avatar
Hey guy..What if the problem is not on the bleeding clutch..What if it something else? Because sometime I come to a stop and then try to put it into gear..it won't go into any gear..Unless I turn off the car then turn it back on..n now I could put it into gear.
Old Jan 2, 2003 | 02:00 PM
ragejed's Avatar
Listen..we are not saying that is THE probelm..
If you can not get your car into gear..maybe the clutch isnt disengaging fully. Therefore it could be you need to bleed your clutch.
We are trying to rule out the simple things and help you dude.
Old Jan 2, 2003 | 02:04 PM
Eva01's Avatar
It could be a bad master cylinder, which most tegs seem to have at one time or another. Look and see if your clutch resevoir is low on fluid. Also look for leakage where your where the clutch rod goes into firewall. If you see fluid leaking there that is an indication that the master cylinder has gone bad.
How many miles do you have on the clutch. It could be going out. Symptoms of a bad clutch are things such as: clutch chatter, mushy or light pedal feel, difficulty in getting in and out of gear, clutch slippage...If it's under warrenty have the dealer look at it.
HTH
Old Jan 2, 2003 | 06:32 PM
djtony5's Avatar
Default Re: Help!!!!! Clutch.... (Eva01)
hehe thanks for the answer guy...I think it my clutch going out now..because the pedal feel musy and shatter sometime and it hard to shift in between gear..It like I have to force it..and everytime I start off first gear..it feel like it want to stall..So thanks guy..Now I want to know how much would it cost to get a new clutch install?? any ideas? and no the car is not under warrenty..
Old Jan 2, 2003 | 06:37 PM
ragejed's Avatar
Try crusin down a road in 5th gear..jab at the gas..if the rpms move up alot..thats a sign your clutch is goin
92sully
Sep 17, 2010 08:19 AM
kojack_0
Feb 10, 2010 12:39 PM
just4747
28
Dec 5, 2004 11:30 AM
ILoveTegs
Apr 7, 2003 07:20 PM
