power window question
Old Jan 2, 2003 | 11:33 AM
Leets's Avatar
Default power window question
For some reason, the power windows in my EG sedan don't want to all work properly. For example, the pass. front window will roll down using the switch on that side, but will only roll up using the driver's switch. Also, the driver's switch will roll down the rear left window, but won't roll it up... that has to be done using the switch in the back. The driver's window is tempermental at times, as well. I don't think this is just a matter of the motors themselves considering the fact that you can still use other switches to make it function properly, and I doubt all the motors would go out at the same exact time. I've heard of similar problems with Hondas where they ended up replacing the entire system only to discover the problem was a relay. So I've been looking for a power window system relay at HondaAutomotiveParts.com but can't seem to find one. Can anyone help out with this problem?
Old Jan 2, 2003 | 12:06 PM
Sohc-Vtec's Avatar
Default Re: power window question (Leets)
I had a similar prob with my 96 sedan. my drivers side switch worked, but my passenger window would not roll down. to remedy the situation i just bought a new switch from the dealership, took off the door handle and swapped it in. now it works just gravy. its pretty cheap u should try that first.
Old Jan 3, 2003 | 12:13 AM
Leets's Avatar
Default Re: power window question (Sohc-Vtec)
that was another thought I had, but I still wonder why both front switches would go out at the same time.
2sLoJR
13
Jun 23, 2013 01:48 PM
rwp011
Dec 16, 2011 05:13 PM
D16Z6_turbo
Aug 4, 2005 09:21 PM
