Brake Booster Upgrades....WHY?
Old Jan 2, 2003 | 09:02 AM
crxgurlllll's Avatar
Default Brake Booster Upgrades....WHY?
I notice everytime someone asks what a good brake upgrade would be someone always chimes in with "swap the booster and master cylinder from XXX car"
Yet there is never an answer as to WHY this is done...personally i think its a pain in the *** to swap out.
I understand if this is done to fit a certain Master Cylinder...but if its done purely from a booster standpoint....what exactly is to gain from using a bigger Booster? and what exactly does the booster do?
Old Jan 2, 2003 | 09:16 AM
Doctor CorteZ's Avatar
Default Re: Brake Booster Upgrades....WHY? (I Want An Si)
to keep the correct bore size on the booster / MC combo
its a 20 minute swap , I wouldnt even call that close to a hard swap.
Old Jan 2, 2003 | 09:21 AM
Spade's Avatar
Booster.....more fluid less movement, more pedal feel.
Old Jan 2, 2003 | 09:26 AM
DOMKID's Avatar
From what i heard, you have to stomp on the brake less than you would normally do. I would like to know the reason for this swap also.
Old Jan 2, 2003 | 09:28 AM
Default Re: Brake Booster Upgrades....WHY? (Spade)
the master cylinder gives you more fluid & less movement
bigger bore pushes more fluid....the master cylinder pushes same amount of fluid regardless of booster presence
Old Jan 2, 2003 | 10:45 AM
ScubaStevo80's Avatar
When you upgrade to bigger disc brakes, you need to push more fluid to make the car stop as it originallly did... if you leave the booster and m/c stock, your brake pedal will feel like mush and not leave u with much braking control...
Old Jan 2, 2003 | 11:55 AM
exactly.
BUT when you swap the MC to use the old booster you need to mod it to fit , easier just to swap both and call it a day.
j3wman
Jun 27, 2012 03:16 PM
mattbatson
Oct 23, 2008 07:30 PM
Leb_CRX
Apr 30, 2005 04:29 PM
crxgurlllll
Jan 2, 2003 12:41 PM
