When running SMC and 450cc do i still need inline fuel pump or intank.....
Old Jan 2, 2003 | 06:53 AM
KevronsEG's Avatar
Default When running SMC and 450cc do i still need inline fuel pump or intank.....
thansk guys
Old Jan 2, 2003 | 06:59 AM
speedymon's Avatar
Default Re: When running SMC and 450cc do i still need inline fuel pump or intank..... (CIV616)
Intank should be fine. You don't need the 100+ psi fuel pressure to push 450ccs
Old Jan 2, 2003 | 07:24 AM
incogNitto's Avatar
I'm pretty sure one of the key features of the SMC is being able to use larger injectors without upgrading your fuel pump, so you should be okay.
Old Jan 2, 2003 | 07:56 AM
ITR981002's Avatar
Default Re: When running SMC and 450cc do i still need inline fuel pump or intank..... (incogNitto)
You don't need a new pump, but I used a stock DSM turbo pump in my car. Usually the guy that your buying the DSM 450s from will also have his stock pump laying around so you can ask him to give you that too. Its a direct plug in for 5G civics.
Old Jan 2, 2003 | 08:12 AM
KevronsEG's Avatar
Default Re: When running SMC and 450cc do i still need inline fuel pump or intank..... (gothatch)
so all i need it smc and 450cc with stock intank
Old Jan 2, 2003 | 10:12 AM
ITR981002's Avatar
Yup, that will work fine. Don't forget the resistor box!!
Old Jan 2, 2003 | 10:15 AM
KevronsEG's Avatar
its in a crx any speacial stuff i need
Old Jan 3, 2003 | 09:22 PM
willyboyK20's Avatar
anybody body know the max boost u could run on the smc and 450cc injectors without a upgraded fuel pump.
Being particular to my setup I also gonna have a 3" exhaust and 2.5" downpipe and i'm guessing that will flow better meaning more fuel will be needed.
Old Jan 7, 2003 | 08:01 AM
ITR981002's Avatar
Default Re: When running SMC and 450cc do i still need inline fuel pump or intank..... (willyboyD16)
Each car is a little different, my guess would be 9-10 psi
joey1320
Jul 29, 2003 01:11 AM
ridnmyhonda
Apr 1, 2003 01:00 AM
1tyme
Oct 22, 2002 12:36 PM
rjardy
Oct 14, 2002 08:15 AM
DJ0820
Aug 1, 2002 11:56 AM
