J&S safeguard v2 timming issues ?
Does the J&S safeguard allow more than 15 degress timming advance on the Distrubutor ? After, I installed it I cannot advance the timming more than 15 degress on the B18C1. Has anyone every run into this problem? Also, I am NA. I just wanted to ask the question here because some of you guys use the Safeguard.
No, it does not limit your timing.
I ran as much as 19 BTDC with mine. Make sure that the service jumper is shorted when you set your timing.
Sonny
