tach drops when rpm activation switch is plugged in
Old Jan 1, 2003 | 03:45 PM
Crxfanatic15's Avatar
Default tach drops when rpm activation switch is plugged in
I was just wondering if anybody knows why it does this and how i can fix it?
Old Jan 1, 2003 | 05:04 PM
the DR.'s Avatar
Default Re: tach drops when rpm activation switch is plugged in (Crxfanatic15)
if you're tapping/splicing into the wire then both won't work at the same time, you need to hook them up inside the distributor and they should both work.
Old Jan 1, 2003 | 06:19 PM
USDM 4G VTEC's Avatar
yeha... if u have a tach and u splice the cable to get signal for the RPM switch it wont work...
u gotta take the RPM signal cable for the MSD switch to inside the Distribuitor.... take the cable and put it on the (--) negative side of the coil.... juss loose the screw and tap the cable in there.... that should give u the signal u want....
Old Jan 1, 2003 | 06:32 PM
Default Re: tach drops when rpm activation switch is plugged in (JDM EF9)
the negative side of the coil gives an rpm signal?
Old Jan 1, 2003 | 06:34 PM
yes
dont be hesitating about it... when i got that installed i didnt know that... a fellow HT member told me and worked... go do it now.. wont take u even 4 minutes... and come back and let us know...
Old Jan 1, 2003 | 07:28 PM
Jared's Avatar
the negative side of the coil is your rpm signal, every 4 fires is a camshaft rotation which is 2 crank shaft rotations. the msd box, tach, whatever figures that out.
Old Jan 2, 2003 | 05:30 AM
Default Re: tach drops when rpm activation switch is plugged in (Jared)
thank you for your help guys
Brain3208
Jan 18, 2006 11:58 AM
Tinker219
Sep 17, 2004 04:15 AM
JSPECHB
Feb 16, 2004 07:26 PM
USDM 4G VTEC
Jul 13, 2002 11:38 PM
rioninja
Jun 21, 2001 11:22 PM
