vtec crossover
Old Dec 31, 2002 | 08:39 PM
alvin6048's Avatar
Default vtec crossover
when does the vtec crossover occur on my f23 in my 98 accord 5spd? just curious.
Old Jan 1, 2003 | 10:06 AM
Brandon's Avatar
Life is Suffering
Default Re: vtec crossover (alvin6048)
It's around 4000 rpm, however, it's dependant on a lot of factors when it actually does change. Where in Charlotte are you?
Old Jan 1, 2003 | 10:10 AM
alvin6048's Avatar
Default Re: vtec crossover (Brandon)
denver. i work in meyers park. i'm guessing you live in charlotte. what part?
Old Jan 1, 2003 | 10:12 AM
Brandon's Avatar
Life is Suffering
Well, I was in Charlotte. I'm in Greensboro now. I was at UNCC.
Old Jan 2, 2003 | 05:32 AM
jweller's Avatar
The F23 has variable high cam engagement. it can be as low as 2300, up to 3500 depending on throttle position and manifold pressure.
low cam leaves one intake valve almost closed to promote mixture swirl in the combustion chamber. VTEC for lean burn and fuel economy.
Old Jan 2, 2003 | 04:20 PM
alvin6048's Avatar
Default Re: vtec crossover (jweller)
when i open the throttle up all the way at low speeds (5-10mph) in second gear, the car kinda jolts between 2000 - 3000 rpms. is this jolt i feel vtec engagement? i always thought engagement was alot higher than that. so vtec engagement depends on throttle position... when i'm doing 80 down the highway in 5th gear with the engine spinning about 3000rpm under light load, i'm pretty sure vtec isn't engaged. but does it engage if i transition to full throttle (without downshifting)? sorry, i'm just ignorant and curious.
Old Jan 2, 2003 | 04:33 PM
Razor's Avatar
he is right, most SOHC VTEC motors have variable high cam engagement. also, make sure your engine is warm or it won't engage vtec. DOHC VTEC on the other hand has a permanent engagement point, like the h22 engages vtec at around 5700-5800 rpm every time...(im not sure on the rpm, its just an example).
Old Jan 2, 2003 | 06:41 PM
ChopsVtec2.2cl's Avatar
Default Re: vtec crossover (Razor)
my sohc vtec f22 on my cl allways crossis over at 5500rpm and it sounds like a h22 dohc vtec when it crosses over
Old Jan 2, 2003 | 10:26 PM
iam7head's Avatar
Default Re: vtec crossover (ChopsVtec2.2cl)
"my sohc vtec f22 on my cl allways crossis over at 5500rpm and it sounds like a h22 dohc vtec when it crosses over"
WOW....
Old Jan 3, 2003 | 10:18 PM
iam7head's Avatar
Default Re: vtec crossover (slo_accord)
Good job johnny..too bad you can't eat my gsx-r for supper. Jk
any pic of the set up bro?
cr757gsr
Oct 9, 2009 01:01 PM
401tuner
Jun 17, 2007 08:36 PM
Jizzmaster Zero
Oct 1, 2005 09:08 AM
Audi2Honda
Jul 19, 2002 12:55 PM
Swerve
Oct 7, 2001 10:24 AM
