supra turbo injectors in honda
Old Dec 31, 2002 | 02:03 PM
DLB1994's Avatar
Default supra turbo injectors in honda
do supra turbo injectors bolt right in a honda fuel rail
87-92 (7mgte) engine are they 550cc
Old Dec 31, 2002 | 02:25 PM
MikePalm's Avatar
Default Re: supra turbo injectors in honda (DLB1994)
they are 440cc low impedance. They should fit fine in the fuel rail, but maybe not perfect in the intake manifold.
[Modified by MikePalm, 11:26 PM 12/31/2002]
Old Dec 31, 2002 | 02:58 PM
BoostedED9's Avatar
Default Re: supra turbo injectors in honda (MikePalm)
i am runing the celica all trac injectors wich ar teh same thing as those, you have to force them a little to get them into the intake mani but after you get them in just put on teh rail and they will stay and work fine, i did not bore out the stock o rings or anything, make sure you got the clips for them too b/c you will have to cut and splice them in place for the stock ones.
Old Dec 31, 2002 | 03:01 PM
DLB1994's Avatar
Default Re: supra turbo injectors in honda (BoostedED9)
aright thanks i was thinking they was 550cc
Old Dec 31, 2002 | 03:05 PM
BoostedED9's Avatar
the 93+ were 550cc injectors but they are side feed
Old Dec 31, 2002 | 03:17 PM
DLB1994's Avatar
are you sure they 450cc not 550cc http://www.allmotorhonda.com/techpages/injector.htm
Old Dec 31, 2002 | 03:43 PM
DLB1994's Avatar
i just went to look at my brother lexus GS-300 they say its the same motor as the supra its a 96 and there top feed just like a honda
Old Dec 31, 2002 | 03:50 PM
simple4012's Avatar
New User
MK IV supra injectors willl not work in a honda. they are far to short
Old Dec 31, 2002 | 03:51 PM
MikePalm's Avatar
That table is not 100% correct. They are 440.
Old Dec 31, 2002 | 03:52 PM
Phoenix GSR's Avatar
mk4 injectors are 550 and they are definately useless to us.. the mk3 injectors are 440cc and we can use them (with a resistor) , just like the dsm's
Old Dec 31, 2002 | 03:56 PM
BoostedED9's Avatar
his car is n/a, so they are prob top feed but i doubt it, i work on supra's daily (not many n/a models) and we make our own fuel systems for the supra so i know what teh stock supra tt fuel system is like..
drumking15
Feb 3, 2005 02:41 PM
Bintegra
14
Jul 29, 2004 08:11 PM
Dragger817
Mar 19, 2003 02:01 PM
CRVRX
Jan 29, 2003 03:21 PM
baonest
May 20, 2002 09:11 AM
