What 550 cc injector fit Honda, Not RC
Re: What 550 cc injector fit Honda, Not RC (CRVRX)
1993-up RX-7 Twin Turbo comes it a few different versions 550 & 850cc injectors. I have a set they look pretty similar to our injectors, havent really tried mounting them up, since I am going to get them balanced first. But I think with some modifications they could be made to fit in our rail... btw, you will need to get 2 sets from these cars, since they have 2 cylinders..
Jeff
Jeff
Re: What 550 cc injector fit Honda, Not RC (AbaZ)
Jeff
Jeff
The 92 and earlier RX-7 have injectors that are top-feed and compatible the Honda fuel rails. Here's a break down
84-85 GSL-SE - 680cc injectors(low-imp) 1st year of the fuel injected 13b rotary engine. Only used 2 per engine though. Mazda realized that this approach didn't work very well so in the later years they swiched to the 4 injector setup.
86-87.5 non-turbo - 460cc injectors(low-imp)
86-87.5 Turbo/Turbo II - 550cc injectors(low-imp)
87.5-92 non-turbo - 460cc(high-imp)
87.5-92 Turbo/Turbo II - 550cc)(high-imp)
93+ - Side feeder's 550cc primaries and 850cc secondaries. Somebody correct me if I am wrong.
Re: What 550 cc injector fit Honda, Not RC (Speed PHreak)
Thanks for the info.
I will try to pick some of the 86 TurboII injectors. Does Mazda have a Forum like HT so I can find some.
Thanks again.
Thanks again.
You know what, I am thinking the injectors I got are not even the turbo model injectors, The engine was already gone, and the intake manifold was in the trunk on both. One of the cars had some turbo badging on them. So I wasnt sure if the other was or Not. The injectors looked identicle on both, so I took all 4 of them. Side feed? as in? The injectors I got look just like normal Nippon-Denso Injectors, they do look to sit a bit taller, but thats it. I am going to get them flow checked to see what they even are.
I was unaware they used 2 different style injectors on the turbo motor, (differnet sizing for the twin setup)
Jeff
Jeff
N/A Supras had saturated (Honda style) injectors... might have been 450's though?
Anyone seen it?
DSM 555's can work with a little adapter thing...
Anyone seen it?
Re: What 550 cc injector fit Honda, Not RC (EpDarks)
Jeff
Jeff
These are some of the kind that the 93+ RX7's use. They're side feeders. I've never seen any up close but obviously they're a bit different than our stockers.
These are the type that the older 1st and 2nd gen RX7 use. Most likely the type you found in the yard. My guess it somebody just chunked an intake mani from one of the older RX7's in the back of one of those newer one's at the 'yard. It's all junk to them, so i'm sure they don't care if people get the wrongs parts. Either way if they're from a turbo car or not ,you're guarenteed to have at least a 460cc'rs.
If you test the resistance across the connector you'll be able to tell what year car the came from.....if you care
[Modified by Speed PHreak, 12:14 AM 1/28/2003]
ahh, yes the 2nd pic looks similar to the injectors I got. I am assuming this are saturated style injectors... but I could be wrong, what are the resistance values for the cars? got a list?
Nissan's have injectors similar to the first pic. "side feed" With the O-ring up top like that. Makes sense.
TY,
Jeff
TY,
Jeff
Thanks for the good info Speed Phreak.
I have never heard of the SDM having 515cc, I have the 450 s right now( Low Imp).
Do you know the year or model of the 515cc's DSM's.
Thanks again, John.
Thanks again, John.
I have never heard of the SDM having 515cc, I have the 450 s right now( Low Imp). Do you know the year or model of the 515cc's DSM's.
1993-up RX-7 Twin Turbo... btw, you will need to get 2 sets from these cars, since they have 2 cylinders..
Jeff
Jeff
Re: What 550 cc injector fit Honda, Not RC (BlueShadow)
I believe MK3 supra's will work--they are top feed and 550. Not sure if they peak/hold or saturated.
Re: What 550 cc injector fit Honda, Not RC (swrdply400mrelay)
Will the high Imp injectors work with the obd-0 ecu if the resister box is by passed?
What year are the 550 Supra high impeadance injcectors?
[Modified by CRVRX, 12:21 AM 1/30/2003]
SunkistRex
03-28-2004 07:33 PM
Acura_I-RS
07-17-2003 07:00 PM
