question on wiring vtec
Old Dec 30, 2002 | 07:29 PM
wu tang's Avatar
Default question on wiring vtec
ok....so i have a 91 std. civic. last night i to the dx to zc wiring and thats done. so now i have to add my vtec solenoid,fuel presure solenoid,2nd o2,vtec oil presure. so i know what pins they go in, but what wire are they? i know the oil presure is on the dizzy(black/yellow) wire.i know where the o2 is. but the vtec solenoid is the one with 2 wires? or the solid black wire on the other plug on the vtec soleniod. thanks for the help. andyes i did try to search.
Old Dec 30, 2002 | 08:10 PM
B20zvtecek's Avatar
Default Re: question on wiring vtec (wu tang)
ok the Vtec solenoid has only 1 wire
the vtec oil pressure switch has two, the black one is a ground , just ground it to the nearest 10mm bolt
vtec oil pressure is between dizzy and vtec solenoid, its green in color
hope this helps
Old Dec 30, 2002 | 11:01 PM
wu tang's Avatar
Default Re: question on wiring vtec (B20zvtecek)
but witch one is the fuel pressure? cause you just said that those are both vtec oil pressure
Old Dec 30, 2002 | 11:09 PM
B20zvtecek's Avatar
i dont think there is such thing as a fuel pressure solenoid??
Old Dec 30, 2002 | 11:30 PM
wu tang's Avatar
http://www.hasport.com/Tech/Wring/Co...1%20DX-SiR.htm, go to that page, and see the coparisent and the fuel thing was on there. so the vtec sol. is the black wire?? and the green is the fuel?? and the one with 2 wires, a black and blue is the oil presure?
Old Dec 30, 2002 | 11:35 PM
wu tang's Avatar
or...could the presue fuel thing, be a vtec presure switch?
Old Jan 2, 2003 | 05:36 PM
seanxhonda's Avatar
hey man,
i have a 92 hatch (cx) and i put a d16z6 in it. i changed the ecu over and my check engine light is on. i don't know how to read the errot codes or anyhting. i had to change over my ecu to a p28 and i was told i need to fix my 02 sensors. can u help me out with that. seaxnj (screen name)
95fourdoor
Aug 29, 2012 01:01 PM
eat_sleep_ej1
12
Dec 1, 2007 04:43 AM
BoOstInHaRd
Mar 24, 2005 10:34 AM
