wierd new hesitation
once i start crusin, i feel it the most. its been ever since i got the cams put in.
as i push the pedal from like 10%-50% dwn it goes thorugh "dead" spots where the car will drop back a little thenpick back up. anyone have any starting points?
John, it might your low throttle settings on the vafc.
Did you guys check the idle to 4k at part throttle on the dyno?
Might be running to rich or lean, due to the cams.
If you want we can check it thursday at the meet.
Also, check your plugs? what kind you running also?
LATER
LATER
LATER
LATER
he did a partial throttle run, so we could set it. the plugs look good. i just chekced them today. we wil talk more about it at the meet.
91b18a1ls
Aug 14, 2016 05:36 PM
