gauge cluster swap
Old Dec 29, 2002 | 09:24 PM
gvillehnut's Avatar
Default gauge cluster swap
What modification and/or wiring is involved in switching my stock 90 crx cluster to a jdm style cluster (teg, civic, etc.) to get the rpm and speed dials higher? And will my warning lights and others work properly also?
[Modified by black90b16, 1:25 AM 12/30/2002]
Old Dec 30, 2002 | 09:04 AM
turbo_civic's Avatar
Default Re: gauge cluster swap (black90b16)
hey, i did a 91civic cx to an si swap, and i also swapped the dash boards, you have to make sure you have the proper wiring and the cable that goes from the speedo to the tranny the rest i think is just elecrtical going to the ecu.
but i'm not 100% sure
Old Dec 30, 2002 | 10:13 AM
Kataku2K3's Avatar
Default Re: gauge cluster swap (4thGenTurbo)
I just swapped a JDM GSR (SiR-G) cluster into my friend's 88 CRX.. There's not to much to it besides rewiring the plugs and adding in an electronic VSS.. Good Luck
Old Dec 30, 2002 | 12:51 PM
gvillehnut's Avatar
Default Re: gauge cluster swap (Kataku2K3)
Whats the difference between the vss's, and how would i go about installing an eletronic one? Also where or what car can i get one from?
Old Dec 30, 2002 | 05:26 PM
Kataku2K3's Avatar
Yours is mechanical using a cable driven speedo that then creates a pulse within the cluster... The electronic VSS creates a pulse which is then sent to the cluster and the ECU... You will have to find one from a 92+ tranny that is equipped with an electronic VSS... You'll have to rewire it in a bit differently and there are mainy ways to do so... I tapped the power and ground directly off the ECU..
SpeedDemonRex
Apr 13, 2013 06:25 PM
CokeZero
11
Jan 19, 2009 11:19 AM
Project_EF
12
Feb 11, 2005 07:19 AM
TiggsCRX
Mar 1, 2004 08:36 AM
S13 slide
Sep 24, 2002 12:03 AM
