Question to those with ground control kits
Old Dec 29, 2002 | 03:28 PM
ncrx1's Avatar
Default Question to those with ground control kits
There's a couple of things I wanted to know about the ground control kit. I have koni yellows and was thinking of getting the threaded sleeve kit from koni. It comes in two sizes 2.25 ID spring or 2.5 ID spring perches. I know the ground control uses 2.25 ID springs and was wondering if the springs that come with the kit are wider or narrower than oem springs? or Are they identical in diameter?
I should clarify that i want to reuse my h&r race springs with the koni sleeve kit if possible. I have measured oem springs, the ID is 2.4inches with an OD of 3inches. I'm not sure if my method of measurement is correct though.
Thanks for the help
[Modified by ncrx1, 6:43 PM 12/29/2002]
Old Dec 29, 2002 | 08:37 PM
Ricky Rojales's Avatar
Default Re: Question to those with ground control kits (ncrx1)
Call ground cotnrol directly. They will know fact from hearsay and customize the application you require.
MrOsvaldo221
Suspension & Brakes
Nov 29, 2013 12:51 AM
lowgman
Suspension & Brakes
Sep 22, 2005 10:56 AM
Mr HYDE
Dec 20, 2003 01:32 AM
ncrx1
19
Jan 11, 2003 05:58 PM
tr4il
Nov 20, 2001 04:09 PM
