Rear shock mount bolt broke off...what to do?
Old Dec 29, 2002 | 03:02 PM
ls-t del sol's Avatar
Default Rear shock mount bolt broke off...what to do?
Its that lower mounting bolt for the rear shocks, the head broke right off
Im in the process of drilling it out right now, any suggestions on how to get it out? I hear that i need a new bushing too, is that true and can i do it myself? Is the car driveable with that bolt head broken off? AAAHH!! This is the most frustrating thing EVAR!!!!1!!1
Old Dec 29, 2002 | 04:27 PM
bennyj's Avatar
Default Re: Rear shock mount bolt broke off...what to do? (SolReaver)
It's a 96-98 Civic Isn't it
Old Dec 29, 2002 | 05:03 PM
Default Re: Rear shock mount bolt broke off...what to do? (bennyj)
Nope its a 95 del sol...ive given up trying to work on it for tonight.
I hope one of these things work out-
1. Drill through the bolt until there is nothing left, then use a new one.
2. Some how grind off the lower part of the shock (part that has the bolt holes) Then just tap it through the other side
What do you guys think? Any other suggestions?
Old Dec 29, 2002 | 08:34 PM
Ricky Rojales's Avatar
You could press it out and put in some urethane bushings.
Old Dec 29, 2002 | 11:23 PM
s73's Avatar
s73
New User
make sure that the bolt was not frozen in the bushing....i have seen that more then once (tags, 6g civics), if that is the case, cutting the nut (you know, the one welded on the shocks) would not likely to help the problem, I ended up sneaking in a hacksaw between the bushing and the shocks and cut the bolt on BOTH SIDES. (because the bolt was frozen inside the bushing, and just cutting one side and banging it out w/ a hammer does not work) If you are going to change your shockes anyways, just cut one of the legs off of the "n"
you need to press bushings out w/ a press, and press new bushings back in (prothane bushings and OEM bushings), or just use energy sus. bushings, (for those u re-use your old shells...which you burn the crap out of them, pop them out, and then just clean and install new bushings)
Old Dec 30, 2002 | 10:02 AM
Batoutahell's Avatar
Default Re: Rear shock mount bolt broke off...what to do? (s73)
Both my rear shock bolts froze to the bushings. On one side the bolt head snapped off. On the other side, the bolt snapped in 1/2. In both cases, I removed the shock/lca assembly, broke the welds on the nuts, removed the nuts, and used a BFM and punch to drive the bolts through the bushings. Not fun, but it worked on both sides.
B18EG6
Suspension & Brakes
Aug 31, 2008 11:24 AM
B18G
Jan 6, 2004 08:48 PM
CoolKat
42
Jul 17, 2003 08:36 AM
logictron2000
15
Apr 24, 2003 08:59 AM
eviladam
Jul 5, 2001 01:26 PM
