"Pusher" type radiator fan
Old Dec 28, 2002 | 10:10 PM
CzanSOHC's Avatar
Default "Pusher" type radiator fan
I wanted more room for my filter and inlet pipe and so added room to work w/...so I decided to change from my stock "pull" type radiator fan to a thinner, "push" style fan.
I bought the fan from Jegs.com part number 778-67012.....12" proform universal fan. $71.99.
First, simply unclip and unbolt the stock fan.
here is a look at new vs old
Now, since the proform fan comes out of the box intended for "pull" type function....you have to "flip" the fan blades. Simply unbolt the 8 mm nut and flip the blades over.
Now mount the new fan using the 4 mounts provided. Then slide the zip tie threw the mount, then threw the radiator core and attach the locking tab provided. (All this stuff comes w/ the fan).
Once mounted, simply cut the clip of the old fan...and splice in the new fan wires. For some odd reason black is power(12v) and blue is the Ground. make sure you cover all connections w/ eletrical tape.
Then your done...here is a pic of the finished product .
Old Dec 28, 2002 | 10:19 PM
len's Avatar
len
Default Re: "Pusher" type radiator fan (CzanSOHC)
Nice setup.
Question: If you were to retain your factor A/C system and PS, is there room to mount the pusher fan? Or do you have to move the pipes to accomodate?
Old Dec 28, 2002 | 10:24 PM
CzanSOHC's Avatar
Default Re: "Pusher" type radiator fan (len)
Nice setup.
Well, I ripped out my A/C ...but yea...you would still have plenty of room to mount the "pusher" style fan just like this only on your A/C condensor...you might have to slighty bend one small A/C line that runs from the relay box..but it should be no problem.
Old Dec 28, 2002 | 11:11 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
wow, thats funny, i just bought the same radiator this afternoon and installed it right after, i saved MAD room, i was pretty happy, im anxious to see how the cooling issues holds up.... One thing i wasnt sure of was u said u had to "flip the blades"... i did not do this, on the fan shroud, it said the airflow was pointing inward, so i simply mounted it the way the air should flow.. ill take soem pics tomorrow, any more input welcome, thanks...RON
Old Dec 29, 2002 | 07:47 AM
AVATAR's Avatar
Looks the same as this, but you spent more.
https://honda-tech.com/zerothread?id=342105
Old Dec 29, 2002 | 03:45 PM
tony1's Avatar
Default Re: "Pusher" type radiator fan (AVATAR)
Different brand. Fans can range in price from $50 to over $200. The quality of the motors and design of the blades makes a big difference in cooling effectivness.
Old Dec 29, 2002 | 04:06 PM
AVATAR's Avatar
Default Re: "Pusher" type radiator fan (tony1)
I realize they are different brands by looking at the design, so are you saying the one from autozone is weaker than this one? It flows 850 cfms.
Old Dec 29, 2002 | 04:09 PM
tony1's Avatar
I don't know which one is better, you would have to compare the flow rates. The more cfm the better the cooling, but that still doesn't tell you the quality of the motor. You can pretty much go by the rule of life, you get what you pay for...
Old Dec 29, 2002 | 04:23 PM
FBP Si 2000's Avatar
Nice writeup...I should consider doing this.
Old Dec 29, 2002 | 06:36 PM
a z n t a k's Avatar
Default Re: "Pusher" type radiator fan (FBP Si 2000)
awesome setup... thanks for the advice. I am planning to get the exact same fans.
Old Dec 29, 2002 | 06:41 PM
CzanSOHC's Avatar
Default Re: "Pusher" type radiator fan (a z n t a k)
Thanks guys....i haven't got a chance to actully put it to use becuase my car in kinda under construction....but i'll keep ya posted on the results.
Old Dec 29, 2002 | 07:33 PM
Farnsrocket's Avatar
Old Dec 29, 2002 | 07:36 PM
CzanSOHC's Avatar
Default Re: "Pusher" type radiator fan (Farnsrocket)
Hey jon...did you get my IM about the profec b?
Obama
Mar 2, 2010 05:33 AM
kyle h.
Welding / Fabrication
Jun 22, 2005 07:18 PM
InLimbo87
Jul 21, 2004 07:22 AM
austrian type-R
Mar 12, 2003 04:31 PM
4doorH22
May 3, 2002 06:11 PM
