Rebuilding Tranny
Old Dec 28, 2002 | 09:14 PM
Tadeh's Avatar
Default Rebuilding Tranny
How much do you guys think it would cost to fix a tranny that has problems with 2nd and 3rd gear. 2nd gear grinds (guessing its synchro) and 3rd doesn't always go in (guessing synchro again, maybe worse). Reason i'm asking is because im considering purchasing an ef, but it has these problems. Motor is 1st gen B16, with ~50k miles. TIA.
Old Dec 28, 2002 | 09:34 PM
EF_LSVtec's Avatar
Default Re: Rebuilding Tranny (tadeh)
Repair kit cost around $175 plus consider the labor for about $60 per hour (2 1/2 hour job)...or you can just buy a rebuilt or used tranny for $500. Good luck
Old Dec 29, 2002 | 12:08 AM
Louie B.'s Avatar
A common problem with the EF's is that the engine mounts are getting old and worn out, causing too much slop in the shifter and not allowing it to go into gear. Before wasting money on a big transmission project, check out all of the engine mounts, especially the rear one. Energy Suspension makes a shifter bushing kit that can tighten things up nicely, they also make an Engine mount bushing kit.
edit: sorry, didn't see that it was a b16, the mounts should already be polyurethane, but it wouldn't hurt to inspect them. and the tranny is going to be a JDM unless it's from a 90-93 Integra. JDM trannys need JDM rebuild kits, might be hard to get a hold of stateside, and it would probably be cheaper to get another trans.
[Modified by thumpu77, 1:12 AM 12/29/2002]
Old Dec 29, 2002 | 10:26 AM
Tadeh's Avatar
Default Re: Rebuilding Tranny (thumpu77)
Its from 92 CRX SiR and the motor mounts are brand new.
Old Dec 29, 2002 | 10:33 AM
crxgurlllll's Avatar
Default Re: Rebuilding Tranny (EF_LSVtec)
where do u get synchro kits for 175??
Old Dec 29, 2002 | 10:50 AM
gray89si's Avatar
Where would you get such a tranny rebuild kit? Im assuming that youre getting one for a b series cable clutch tranny such as the 90-93 Integra, or are we talking the 92-93 GSR, but isnt that one a hydro transmission?
Old Dec 29, 2002 | 11:26 AM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
above you said its a 1st gen B16? and then you said its a 92... that would be 2nd gen 5 series... are you confuzed? either way, block, and trans are same mounts, thus the 92 being hydrolic.. either way, i doubt the mounts.. shop for a tranny. in so cal, cables are going for 550 Y1, hydro's 650... YS1 with LSD 750!!!!!!
Old Dec 29, 2002 | 03:15 PM
Louie B.'s Avatar
Default Re: Rebuilding Tranny (eraser)
I don't know about b-series, but I got a kit for my Si tranny that came with all new seals, all new bearings, and all new syncros for $160.00 from my local tranny shop (they happen to be friends of mine so I got it for their cost)
Old Dec 29, 2002 | 03:22 PM
PaImportTuner's Avatar
Default Re: Rebuilding Tranny (Built B16A)
they made 2nd Gen CRXs til 92 in Japan, Netherlands, Europe etc. (88-92) In the USA they were only sold from 88-91.
Hence why he's buying a 92 CRX SiR with ~50k miles. (1st Gen B16a1 w/Cable tranny)
Old Dec 29, 2002 | 08:43 PM
Tadeh's Avatar
Default Re: Rebuilding Tranny (PaImportTuner)
thank you!
Old Dec 30, 2002 | 07:42 PM
Tadeh's Avatar
Anyone else, b16a tranny problem answers?? O yeah and since i got A 92 CRX SiR tranny+motor, can my local shop still order the rebuild kit??
[Modified by tadeh, 5:04 AM 12/31/2002]
Old Jan 2, 2003 | 01:27 AM
Torino91LS's Avatar
I bought a Y1 Jdm trans and the fifth gear synchro is messed up. Can i use the Y1 3rd gear in a JDm s1 case and gear set??
Old Jan 2, 2003 | 10:59 PM
Tadeh's Avatar
Default Re: Rebuilding Tranny (kincaidcrxsi)
Old Jan 3, 2003 | 05:22 AM
keithv's Avatar
courtesy of ayanami:
https://honda-tech.com/zerothread?id=374890
ABlais
12
Jun 17, 2008 11:25 AM
trini-laser
Aug 21, 2005 04:17 PM
ineedboostbad
May 27, 2005 08:09 PM
93egSIboi
24
Feb 10, 2005 04:40 PM
rac3rb0i
Nov 30, 2004 11:02 AM
