what should my compression resutls be???
well i'm about to do a compression test tonight just so know what kind of condition the motor is in. What should my numbers be for a D16a6(90 civic si) it has about 168,000 miles.
any things i should do also? what fuse do i take out to prevent the fuel from injecting?
Great compression would be 185psi across the cylinders. Minimum around 130-135 with a max variation between the cylinders of 28psi. My motor with 120k on it put down 180/180/180/185.
well here are the resutls 175,170,170,170
did the test when motor was warn.
well i''m very happpy about the resutls....... any coments?
hahah dude that's exactly what i was thinking ever since yeaterday night....
before the test i really doubted my OLD 168,000 miles D16a6.. now i look at it didferenly. Pretty decent for that many miles aey!!
B18EG6
Jan 29, 2006 02:24 AM
uhhh... what should the compression be on a Z6?????
