Friends car wont go into reverse HELP!
Old Dec 28, 2002 | 04:39 PM
B0oStnB18C5's Avatar
Default Friends car wont go into reverse HELP!
MY friends type r all of a sudden wont go into reverse any one have any ideas on what could be wrong? all the other gears go in smooth just reverse is stuck.
Old Dec 28, 2002 | 05:08 PM
Phoenix GSR's Avatar
Default Re: Friends car wont go into reverse HELP! (B0oStnB18C5)
once I broke part of my shift fork off shifting too hard.. the little piece was loose in the tranny.. reverse was the first gear I lost.. then I shook it loose and I lost first, but got back reverse... it required a complete tranny rebuild.. luckily it was covered by waranty.. whew..
Old Dec 28, 2002 | 05:17 PM
MiraiZ's Avatar
double-cluch...or bite the bullet and just rind it in..
Old Dec 30, 2002 | 10:34 AM
fredtoast's Avatar
Default Re: Friends car wont go into reverse HELP! (MiraiZ)
I had this same problem. It came out of the blue. I forced it in for a few days. It ground like hell, but before I could get it in a shop the problem disappeared. My ITR is a 98. That was over a year ago, and has never happened again.
Old Dec 30, 2002 | 10:50 AM
Casey's Avatar
Default Re: Friends car wont go into reverse HELP! (fredtoast)
try putting it in 1st and then going in reverse
Old Dec 30, 2002 | 10:58 AM
ragejed's Avatar
Default Re: Friends car wont go into reverse HELP! (Casey)
Just threaten your car that you are bringing it to a shop to get fixed..Lol, cars hate shops, and always seems to get better right before going
Old Dec 30, 2002 | 11:29 AM
GRM Scott's Avatar
25 Year Member
or try leaving it in neutral, then putting the clutch in and out, and try again. sometimes junx needs to be moved around before it wants to engage.
Old Dec 30, 2002 | 12:51 PM
whiteGSR's Avatar
Default Re: Friends car wont go into reverse HELP! (Aleph)
try putting it in 2nd, then 1st, then reverse
that's what i do when my tranny gets finicky..
Old Dec 30, 2002 | 01:03 PM
AssPenny's Avatar
Default Re: Friends car wont go into reverse HELP! (whiteGSR)
Just open the door and push the car backwards with your foot... that is what I do
Craig - Who really, really needs to fix his syncros
Old Dec 30, 2002 | 03:02 PM
Asahi's Avatar
Default Re: Friends car wont go into reverse HELP! (AssPenny)
could very likely be the clutch disk failing at the little springs.
Eiter way don't FORCE it you could bend the shift forks.
Old Dec 30, 2002 | 03:11 PM
ITR184's Avatar
If mine doesn't go into reverse I put in first and let it role just a little bit then put in reverse. my wifes civic si does the same thing but not as often as my itr
Workhard1107
Honda CR-V & Element
Jan 30, 2015 12:37 PM
Mr. TopFuel
Feb 28, 2008 09:12 PM
vteclude07
Jul 3, 2007 02:59 PM
ludatic98
Nov 28, 2006 09:20 PM
deftones0817
Nov 30, 2002 05:49 AM
