window problem :(
Old Dec 29, 2002 | 06:46 PM
done's Avatar
Default window problem :(
I had to take my door panel off to fix a speaker baffle..
anyways.. i plug it in and it does nothing.. the motor doesnt even try to work..
i did come off track, but was fixed.. is there a wire by the motor maybe that came lose?
Old Dec 29, 2002 | 06:50 PM
Eric R's Avatar
Default Re: window problem :( (Jordo)
Get to the motor plug. Unplug it and with a test light check if you got power when you hit the switch up and down. If you got power, means the fuse is ok and your motor might be stucked (sp) or blown. Remember to put the ignition on.
Good luck!
Edit: Sp.
[Modified by Tweety R, 7:51 PM 12/29/2002]
Old Dec 29, 2002 | 07:01 PM
done's Avatar
Default Re: window problem :( (Tweety R)
Good luck!
Edit: Sp.
thanx. ill try tomorrow
Old Dec 29, 2002 | 10:20 PM
B2FiNiTY's Avatar
Which window?
Old Dec 29, 2002 | 10:24 PM
TypeR 599's Avatar
Default Re: window problem :( (B2FiNiTY)
hehe don't pull a dennis, is it locked?????????? haha
[Modified by TypeR 599, 11:39 PM 12/29/2002]
Old Dec 30, 2002 | 01:04 AM
Jmm0056's Avatar
Which window?
haha, do a search on B2's window problems
uNF$@#!'s Avatar
Default Re: window problem :( (TypeR 599)
lmao, i almost forgot about that...his new title explains it all
Old Dec 30, 2002 | 03:14 PM
done's Avatar
Default Re: window problem :( (Soup ****)
nah its not locked... i think the wire on the motor in the window is lose...
gliaZeD
Aug 19, 2011 11:15 AM
Nic
Mar 9, 2009 04:44 PM
jaxbrandon
Jul 2, 2008 05:07 PM
Guineapig
Sep 9, 2007 06:29 PM
2000civicsi
Oct 29, 2005 04:43 PM
